fuel
Old Jun 21, 2011 | 11:07 AM
alphalambda's Avatar
fuel
Hey everyone just joined the online world of Z's. I have an issue that could use some assitance. My '78 Z had a couple fuel leaks that I believe to have fixed; replaced injector hoses and o-rings in the fuel pump. But now it wont start. Im getting pressure in the fuel rail but there is nothing coming out of the return line. I dont know if the whole system needs to be bled or what. Your help will be much appreciated.
Old Jun 21, 2011 | 03:50 PM
Welcome to ZDriver!
Have you verified that your new fuel pump is actually running / priming?
Old Jun 21, 2011 | 05:18 PM
I dont know if it is priming but i can hear it running and i have checked fuel is coming to the fuel rail
Old Jun 27, 2011 | 06:40 AM
theramz's Avatar
I have a present for you...
If it is running it may just be clogged up and mearly making noise with a dribble to the engine. You need 35 psi for the injectors to work right. I you don't have any return fuel it means the pressure regulator doesn't have enough fuel pressure to even open. Check your fuel filters.
Old Jul 21, 2011 | 04:24 PM
thanks for the advice. I ended up buying an OE replacement pump and is running great
ThatDude114
Jun 15, 2014 08:43 AM
RonK
Feb 11, 2013 08:48 PM
mrprofile
Jun 25, 2010 11:23 PM
TeamRonin
Oct 6, 2009 10:24 PM
280zinkansas
Apr 27, 2004 10:26 AM
