Engine oli change
Old Jul 12, 2008 | 06:06 PM
at-jefft's Avatar
Uber n00b!
Engine oli change
Hello,
I just bought a 260z and don't have the owners manual(downloaded service manual). Could some one tell me how much and what type of oil to use when I change the oil on my z? Or somewhere to download the owners manual would be even better. Thanks, Jeff
Old Jul 12, 2008 | 06:44 PM
Your local parts store will have the specs, or you could just google it. In the 240z-260z Haynes manual it says 10.7 pints or 5.35 quarts.
Check out http://www.xenons30.com/reference.html
Old Jul 13, 2008 | 02:17 PM
Well I know...that 10w 30 is a good overall weight for a healthy engine. Also depends where you are at climate wise. It should be the same grade like my 280zx. But I need to use thicker oil..because of my bad cylinder. I use 20w 50 in mine. Because I leak and burn oil. But yeah...10w 30 should be a good overall grade for your Z.
Old Jul 13, 2008 | 04:29 PM
SportBikeMike's Avatar
Political n00b crusher
Like WildmaN said, 10W-30 should be fine. Also, I'd stick with non-synthetic....synthetic oil can cause problems with older engines (if its never been used before).
JoeGasm
Mar 8, 2008 05:01 PM
SportBikeMike
Apr 1, 2007 09:37 AM
speedlimits
Dec 30, 2005 11:43 PM
81 Black L28E
Mar 25, 2005 12:47 AM
wickedshadowz
Jul 28, 2002 09:19 AM
