Engine noise after water pump replaced
Old May 18, 2013 | 12:14 PM
mbgnh1's Avatar
I replaced my water pump and car ran fine then started to make a groaning/ binding noise from the bottom front. The inner pulley seems loose. It is the one the a/c belt turned on, but the belt is now off. Any suggestions?
Old May 18, 2013 | 12:22 PM
Put belt on, tighten pulley.
Also make sure pulley spins freely & is not cocked at a weird angle.
Old May 18, 2013 | 02:28 PM
mbgnh1's Avatar
Thanks for the reply nismo. Is it not possible to leave the a/c belt off? The a/c does not function. Can the outer pulley be removed? Do you think it is binding without the a/c belt keeping it aligned? It makes a god awful noise.
When I replaced the water pump, the inner pulley seemed loose. I expected it to be fixed in place, but it didn't appear to be.
Old May 20, 2013 | 01:41 PM
mbgnh1's Avatar
Crank pulley issues
Crank pulley (inner) was loose and floppy when I put the belt back on after replacing the water pump. It now makes an awful binding noise and must be replaced. I will pull the part with a puller. For a 78 280Z, any tips about removing the pulley? How do I put it back on? Can I go with a single groove pulley if I don't want the a/c? Any lucid feedback appreciated.
Bravenewme
Nov 18, 2014 01:22 PM
scorpionp54
Jun 7, 2009 07:46 PM
nismo619
Oct 31, 2006 10:03 AM
JAMESZ
Apr 15, 2004 08:24 PM
katkins
Sep 4, 2001 07:32 AM
