Early 260z has no spark
Old May 10, 2012 | 02:02 PM
MidlifeZ's Avatar
I took the z out for a short drive one morning, parked it for about an hour, then started right up, died while the choke was on and now won't start. Tried to start with starting fluid and nothing. Checked all of the normal stuff, cap, rotor,plugs-all good. Found I had no spark at plug or coil. Replaced coil and checked connections, still no spark. Is it possible to check the pick up in the distributor? That's where the TCU gets it signal-right? HELP!
Old May 10, 2012 | 02:10 PM
Welcome to ZDriver!
It's probably either the points or condenser. Both should be available at your local parts store for a good price.
Check out the parts in the FSM if you need: XenonS30
Old May 10, 2012 | 02:27 PM
MidlifeZ's Avatar
Mine has electronic ignition, so just the pick up coil inside the distributor. Not sure how I test that.
wallace millner
Sep 20, 2013 02:13 PM
xtasZ
Jan 14, 2005 02:35 AM
kcannaday
Aug 3, 2004 03:16 PM
fattyjay22
May 4, 2004 04:56 PM
rp123
May 14, 2003 05:54 PM
