Early 260z has no spark
I took the z out for a short drive one morning, parked it for about an hour, then started right up, died while the choke was on and now won't start. Tried to start with starting fluid and nothing. Checked all of the normal stuff, cap, rotor,plugs-all good. Found I had no spark at plug or coil. Replaced coil and checked connections, still no spark. Is it possible to check the pick up in the distributor? That's where the TCU gets it signal-right? HELP!
wallace millner
Sep 20, 2013 02:13 PM
