Clutch wont engage(1976 4 speed)
Old Jul 19, 2012 | 05:52 PM
Bucket280z's Avatar
My clutch pedal went soft all of a sudden today and it became hard to put it into gear were i have to force it. When its off it easy to put it into gear until i turn the car on. Do i need to buy a new clutch or is it some small problem? Please help
Old Jul 19, 2012 | 05:55 PM
rogerz's Avatar
Grumpy & Helpful
most likely you need to replace the clutch hydraulics master and slave cylinders
Old Jul 19, 2012 | 06:06 PM
Bucket280z's Avatar
Are both of them located on the drivers side? And what caused this
Old Jul 19, 2012 | 06:38 PM
Click: XenonS30
Old Jul 23, 2012 | 09:13 AM
Bucket280z's Avatar
Should i buy the parts from motosport clutch hydralic master is like $84 and the slave cylinder is $31 i was also wondering about the afm which has a 400 refundable core charge when i send it in and exchange it im confused here!
Old Jul 24, 2012 | 11:53 PM
lifegrddude's Avatar
Externally Wastegated
Don't worry about the afm, it's not needed for the clutch. But if you're looking for a replacement afm, check your local salvage yard. It will be much cheaper than a new one. Last time I bought one it was about 45-50 dollars.
Old Jul 25, 2012 | 11:55 AM
Bucket280z's Avatar
Its cause theres also a problem with the AFM my car revs at 4k only. I have been to the junk and found AFM but from newer models like 77-84 and cant find a 76 anywhere haha. But are the parts from Motorsport legit because i really want to get my car on the road.
Old Jul 25, 2012 | 02:07 PM
rogerz's Avatar
Grumpy & Helpful
buy the clutch hydraulics from napa or oreilly's. they should run around $60 for the set. you can see the master with the hood open driver side. the slave is on the bell housing under the car. 77 afm should work on your 76. what makes you think the afm is haywire. usually it is something else like timing or a vacuum leak.
oh yeah in case you haven't heard parts wear out after 15 years or so. have you got AND READ the fsm world of information in there.
low revs be sure the carpet isn't bunched up under the gas pedal common s30 problem
Old Jul 26, 2012 | 12:03 PM
Bucket280z's Avatar
I bought both parts for $47 on Oreily's damn things were cheaper thanks for telling. Yeah i found where both parts are but whats the other cylinder next to the clutch hydralic does that one need to be changed also? It didnt the 77 Afm had 5 ports while mine had 7. Well i did ask the guys over at Mike Z shop and they told me it was the afm and i also asked around here and they also said it could be the afm. It could be something with the timing because they rebuilt my motors head and how do i check for vacuum leaks cause a while ago my car would do weird suction noises by the air filter but it has gone away.
The car does have all its oem parts on but has been reliable since the rebuild. And whats this FSM world im new to all this.
The car revs at 800 were it's suppose to and my car is stripped of its carpet.
camster
Aug 14, 2013 03:17 PM
Pez
Mar 4, 2013 02:32 AM
turbotim
Jul 4, 2010 07:18 PM
turbotim
Jul 3, 2010 06:15 PM
Darylick
Oct 28, 2002 08:10 AM
