blower motor problems
Old Sep 7, 2010 | 06:35 AM
awconroy's Avatar
the a/c blower motor abruptly stopped working on my 260 last week.
i've reviewed a few wiring diagrams and understand the circuit logic, but can someone tell me where the resistors and relay are physically located, and generally what they look like?
thanks,
tony
richmond, va
Last edited by awconroy; Sep 8, 2010 at 07:10 AM. Reason: changed "fuse" to "resistors"
Old Sep 7, 2010 | 11:29 AM
I've had similiar problems on my 280zx. I will bet your climate control switch is shot. I found out mine was. When I took the blower motor out, and tested it with 2 wires straight from the battery. And it worked just fine. And after eliminating everything else. I determined it was the switch. Just a tip to point you in the right direction. Good luck.
Oh and welcome to Zdriver.
Old Sep 7, 2010 | 05:24 PM
awconroy's Avatar
ok, the fan works.
i jumpered straight from the battery to the pigtail on the back of the fan and it worked fine. but that only eliminates the blower motor itself. still need to test the fuse and relay portions of the circuit, just as soon as i find them.
t
Old Sep 7, 2010 | 07:28 PM
theramz's Avatar
I have a present for you...
The fuse panel on the 260 is behind the ps kick panel. If the fuse is good try the fan selector switch. It is wired through the ignition switch.
Old Sep 8, 2010 | 04:05 AM
t
Right gotcha man. I was just telling you what happened with me. When I checked the relays and fuse. And I really don't know how much different the Z models are. Hopefully you figure out what is going on with it. Keep us posted. And good luck.
davidjoe007
Jun 29, 2021 04:45 PM
stevet
May 4, 2013 11:06 PM
davidjoe007
Apr 16, 2007 08:40 PM
y2ktranny
May 28, 2004 10:26 AM
ZorroZ
May 14, 2003 10:11 AM
