AFM problems
Old 07-12-2018, 06:05 PM
Juffins's Avatar
AFM problems
Ok guys, i have a 78 280z. The engine will randomly die while driving. I'll pull over, struggle to crank it, pull the boot from the afm, spray some starting fluid staight to the tb and she cranks. Recently I figured out I don't even need starter fluid. I just pull off the boot then she starts. She dies soon after. Sometimes ill crank her like this and put the boot on and she immediately dies. Sometimes when I put the boot back on she idles at about 1.8k. Any suggestions?
Juffins is offline
Old 07-15-2018, 09:07 PM
Welcome to ZDriver!
An engine needs 3 things to start (if it's mechanically working properly):
-Proper air delivery
-Proper fuel delivery
-Proper spark delivery
So when it won't start, does it have fuel (fuel pump works? fuel injectors spraying? fuel pressure?)
Does it have spark at all 6 plugs?
When you can start an engine with starter fluid, that means it's not getting proper fuel delivery... either fuel pump isn't working, or injectors aren't spraying.
NismoPick is offline
Old 07-16-2018, 07:07 PM
Juffins's Avatar
Ok so I might have it narrowed, but I want to take time to troubleshoot methodically. However, in the early morning and late evening/ night... aka when the sun isn't up and its not hot out, it doesn't do it. It does it whenever everything heats up. I'm thinking vapor lock...
Juffins is offline
Old 07-24-2018, 09:07 AM
Vapor lock is a carb issue, not fuel injection issue. Check your fuel pressure... should be ~30psi and should not leak down when it's turned off.
savio87
11-21-2017 03:15 PM
redhare
05-25-2017 11:38 AM
bimbobreadman
03-21-2010 06:02 AM
Duck Ryder
07-17-2007 12:45 PM
Oxide
02-21-2006 07:27 AM
Quick Reply: AFM problems
