AFM to 60mm Throttlebody.
Old Apr 17, 2006 | 03:33 PM
TEDS280Z's Avatar
I am going to put in the 60mm tb that i picked up. What am I going to need to replace the hose fron the AFM to the TB? I'm sure this has been done and I know there can be no leaks so does anyone have a proven way to do this?
I pick up the engine Friday and start working on it Saturday. If family and friends forget I even exist.
Old Apr 17, 2006 | 03:43 PM
Here's a similar topic: https://www.zdriver.com/forums/showt...highlight=60mm
You can find a lot of silicone couplers on ebay.... many diff sizes.
Old Apr 17, 2006 | 06:31 PM
i used a afm to air cleaner tube from a turbo zx, its the right diameter, and it has the right bend if you cut it to the right length. it doesnt include a spot for the cold start equptment, but that could always be adapted. ill post pics if you would like
Old Apr 17, 2006 | 07:46 PM
TEDS280Z's Avatar
Throttle body hose
Some pics would be great Thanks First car I've ever rebuilt so I really appreciate all the help I can get I just read the other post. What will a turbo afm do with a non-turbo? I've never heard of this being done. Whats the improvement?
Old Apr 18, 2006 | 05:42 PM
the turbo afm with n/a guts just flows a bit more air, its harder to plumb and isnt worth it if your car isnt modified very much, ill go get you some pics.
Old Apr 18, 2006 | 06:00 PM
here ya go.
here some with the turbo afm its hard to make it fit.
hope those help
Old Apr 18, 2006 | 08:38 PM
jfairladyz's Avatar
I had to swap a turbo AFM into my NA chassis and it was a PITA to get that thing to fit right. I just ended up cutting the original AFM bracket out and installing the AFM upside-down to gain plenty of clearance. Of course I swapped the entire turbo engine in with the AFM It's a little more difficult then making it fit with an NA motor cause you dont have all that room due to the J-Pipe being in the way.
Old Apr 18, 2006 | 08:42 PM
I hear ya loud & clear on that one big buddy... and it gets a wee bit more tight w/ IC pipes.
Old Apr 19, 2006 | 01:20 PM
TEDS280Z's Avatar
Thanks
Thanks for the pics now I understand what I need.
NismoPick
Nov 29, 2008 10:28 AM
TEDS280Z
Feb 6, 2006 02:03 PM
mescalinedreamz
Aug 1, 2003 05:35 AM
chris
Aug 9, 2002 09:49 AM
samzman
Mar 7, 2002 11:30 AM
