AFM to 60mm Throttlebody.
I am going to put in the 60mm tb that i picked up. What am I going to need to replace the hose fron the AFM to the TB? I'm sure this has been done and I know there can be no leaks so does anyone have a proven way to do this?
I pick up the engine Friday and start working on it Saturday. If family and friends forget I even exist.
Here's a similar topic: https://www.zdriver.com/forums/showt...highlight=60mm
You can find a lot of silicone couplers on ebay.... many diff sizes.
i used a afm to air cleaner tube from a turbo zx, its the right diameter, and it has the right bend if you cut it to the right length. it doesnt include a spot for the cold start equptment, but that could always be adapted. ill post pics if you would like
Throttle body hose
Some pics would be great Thanks First car I've ever rebuilt so I really appreciate all the help I can get I just read the other post. What will a turbo afm do with a non-turbo? I've never heard of this being done. Whats the improvement?
I had to swap a turbo AFM into my NA chassis and it was a PITA to get that thing to fit right. I just ended up cutting the original AFM bracket out and installing the AFM upside-down to gain plenty of clearance. Of course I swapped the entire turbo engine in with the AFM
It's a little more difficult then making it fit with an NA motor cause you dont have all that room due to the J-Pipe being in the way.
mescalinedreamz
Aug 1, 2003 05:35 AM
