280z turbo: My journy begins
Old Nov 24, 2009 | 05:44 PM
Blue_streak's Avatar
Ok, so i was able to get my hands on a 1983 280zxt. I will be swapping the engine into my 1976 280z over the winter. I no the engine will bolt in to it with pretty well no mods. The things i am worried about are the drive line, i have read the T5 Borg Warner transmission is not a direct swap, there are some mods needed, but i cant really find a clear write up on it. Also that the drive shaft may not fit properly, is there a aftermarket solution to this? I am also(i have looked and searched for about a week) been having problems finding what other mechanical components if any swap over. I no there is a early 280zx read brake swap write up, but is there a 280zxt brake to 280z set up out there? The wiring is also a point of concern for me, the only write up i have found is for a 1981 i believe, but the 83's wiring will be different. So i guess i am here looking for words of wisdom from the Z gods on these thing, and any other issues i can be looking forward to. Thanks
Old Nov 24, 2009 | 06:02 PM
nope. the rear disc conversion on the 280Z (S30) usese 240sx calipers and Z31 rotors and adapter plates/brake lines. the motor drops in with no problems. the trans i think you just need the mount from the S130 it came with but the driveshaft i think needs shortened? i cant remember for sure on that one. the 83 is a better setup for EFI and a VERY easy wire up. its my fave harness to use so far out of the 82 and 83 (never tried and 81 harness yet)
Old Nov 25, 2009 | 06:27 AM
We don't have an "official" S30 turbo swap write up yet. I'm working on it this winter (lots of crystal clear pics & instructions).
But there is already a lot of info on it around here. Have you checked the S30 motor swap section? https://www.zdriver.com/forums/240z-260z-280z-motor-swaps-non-v8-269/
Old Nov 28, 2009 | 10:26 AM
skittle's Avatar
Taste My Rainbow
I'll try doing a megasquirt install write up to add as well. Regretfully I did not get any pics when I did my swap.
SlicktopS130
58
Oct 13, 2014 07:12 AM
dubai280z
Aug 3, 2014 10:12 PM
81SacUti280zx
Sep 28, 2010 11:41 PM
Torque Solution
Jun 6, 2010 09:25 PM
FubarI33t
Jun 5, 2010 07:56 PM
