280Z Auto stalls when put into gear
Old Nov 2, 2008 | 02:25 PM
CWHammer's Avatar
Under My Car... brb
My son and I were looking at a '76 today that is an auto trans car. The guy said it wouldn't idle - with a twist of the dizzy and tightening the bolt I fixed that. There is the usual bad rubber under the hood but I managed to get the car to idle smoothly. Mechanically it seems fine with the exception of it dieing as soon as I put it in gear. The guy is asking $950 for and I think the body is solid enough for a rebuild/restore. Not having any experience with the auto trans on the Z what should I look for to correct the issue?
Old Nov 2, 2008 | 03:55 PM
280zx2by2's Avatar
Haterade by da gallon!
a 5 speed trans!!!
what was the idle speed at? that seems to be a big issue for auto trans stalling out
Old Nov 2, 2008 | 04:58 PM
CWHammer's Avatar
Under My Car... brb
a 5 speed trans!!!
I like that idea but my kid(who's looking to buy the car) doesn't. Kids these days, spoiled by the automatic trans.
It was holding around a grand to 1200. My '83 idles around 700-900 and the kid said the S30 wouldn't idle so I kicked it up a tiny bit. If I feathered the throttle I could get 'er movin. But as soon as I let off of the gas it died.
Old Nov 2, 2008 | 05:46 PM
Did you check the tranny fluid color & level? It may or may not be related to the transmission. If one of the sensors is out of wack, as soon as there is a load, the engine might not have enough "umph" to move. The TPS, AFM, or timing could cause that.
Old Nov 2, 2008 | 07:22 PM
CWHammer's Avatar
Under My Car... brb
That is a definite possibility. The hoses and lines were pretty rotted and the dizzy was loose and bouncing all over before I tightened it down. It idled good but I bet the timing was still way off. The hose from the AFM to the TB was looking pretty bad too. I think we'll trailer it home and then work from there.
280z78
Jan 14, 2015 04:08 AM
Tonylsg
Oct 2, 2012 07:18 AM
yves280zx
May 14, 2007 07:05 AM
joejoe1129
Oct 21, 2004 02:35 PM
gr8gatZby
Oct 15, 2003 07:09 PM
