240z Coil and Ballast Resistor Installation Help
Old Jan 8, 2013 | 07:44 PM
NCdatsunZ's Avatar
Hi.
I'm installing a new Coil and Ballast resistor and don't remember where everything went
Does the positive terminal on the coil go on the upper side or the lower?
Which wires do you connect to the ballast resistor?
Thanks
Will
Old Jan 9, 2013 | 04:42 AM
Steve260Z74's Avatar
Originally Posted by NCdatsunZ
Hi.
Thanks
Will
The positive terminal on the coil gets a black/white wire. On one side of the resistor, you have a green/white wire. The other side has a black/white wire. I'm not sure what you mean by upper side or lower side. The ballast resistor does not have polarity.
Be sure to download the FSM for your car. The wiring diagram has the details you needed.
Attached Thumbnails 240z Coil and Ballast Resistor Installation Help-240z-ignition-circuit.jpg
salvi
Jul 10, 2014 08:27 AM
duowing
Apr 8, 2008 08:37 AM
vrocious
Sep 27, 2007 06:52 AM
jknust
Mar 21, 2003 11:06 PM
nzz
Feb 20, 2002 04:59 PM
