240z Coil and Ballast Resistor Installation Help
Hi.
I'm installing a new Coil and Ballast resistor and don't remember where everything went :confused: Does the positive terminal on the coil go on the upper side or the lower? Which wires do you connect to the ballast resistor? Thanks Will |
1 Attachment(s)
Originally Posted by NCdatsunZ
(Post 320247)
Hi.
I'm installing a new Coil and Ballast resistor and don't remember where everything went :confused: Does the positive terminal on the coil go on the upper side or the lower? Which wires do you connect to the ballast resistor? Thanks Will Be sure to download the FSM for your car. The wiring diagram has the details you needed. |
