240Z, 260Z, 280Z Motor Swaps (non-V8) L28ET RB SR KA VG VQ 2JZ etc....
Snw's OFFICIAL 280Z turbo build thread - SMPYWD!
Old Feb 2, 2011 | 06:47 AM
  #101
SportBikeMike's Avatar
Political n00b crusher
A chocolate cake?... lol
Send that sucker down! I'm hungry....and snowed in....
Old Feb 2, 2011 | 11:05 AM
  #102
You two having fun in all that snow? My flight through Chicago was canceled...
Still going to Missouri but they only have 3 inches of snow in Kansas City
Old Feb 2, 2011 | 11:09 AM
  #103
we got 18 inches. I had 3.5 foot tall drifts in my driveway though, there are 10 foot high drifts/mounds from the wind plus snow plows. the streets look like a channel system. its awesome! I plowed out my driveway in 2 hours, hopped in the S2000 and went drifting lol. There seems to be no cops, lots of snowmobiles and ATV's and no cars other than me. So I got a lot of thumbs up for not bein a pussaayy
Old Feb 2, 2011 | 11:19 AM
  #104
Good for you!
This time when you slam into a truck your car will crunch and hold together. No rust on that Honda!
Old Feb 2, 2011 | 01:43 PM
  #105
HEY MAN, that truck pulled out infront of me wehn I was 10 ft away heading in a straight line. lol. I don't hit things, they hit me.
also, GIMMMMEEEE mike! lol.
Old Feb 2, 2011 | 02:12 PM
  #106
Soon as I receive that cake...it'll be on its way!
Old Feb 2, 2011 | 02:22 PM
  #107
It wont fit in the envelope...? I tried several times.
Old Feb 3, 2011 | 11:12 AM
  #108
I'm in Missouri. Come visit.
Old Feb 3, 2011 | 11:16 AM
  #109
How is it you are in different states? Are you traveling, because of a job? And if so, what do you do?
Old Feb 3, 2011 | 11:20 AM
  #110
I'm only here for a day. I'll be driving north tomorrow but not going to Chicago.
I'm buying a car here. They cost a lot less over here than in Washington.
Old Feb 3, 2011 | 11:43 AM
  #111
pfffft... no they don't. Z's I notice are cheaper down south and in back country, normal cars I noticed are cheaper in like kentucky and that area...
Old Feb 7, 2011 | 11:54 AM
  #112
Exactly! I told you guys I was going to sell my Z and buy a Scion.
I'm in Spearfish, South Dakota... Scion and SNOW! yikes
Old Feb 9, 2011 | 05:53 PM
  #113
The moment I was dreading is finally over!!!! this is my first attempt at doing quality welding, and I am very happy at how it turned out... total fab time since everything was cut fit cut fit cut fit over and over since the space was so tight was 6 hours!!!! UGHGHGHH
any ways, wastegate plumped!
don't hate on the welds, they aint purty but they are strong and a clean seat all the way around
tight tight tight!!!!!
blam!
ohhhhh nothing like a screamer pipe!
Old Feb 9, 2011 | 06:22 PM
  #114
evandubya's Avatar
Primer Grey FTW!
what did you weld it with?
Old Feb 9, 2011 | 06:57 PM
  #115
260zturbo's Avatar
Stupid Hurricanes...
looking good bud, guess i would be doing the same if i had snow all around me!!
Old Feb 9, 2011 | 07:12 PM
  #116
a 110V mig welder... nothing fancy at all... BUT it actually penetrated very well. However it does make a ton of slag, so I have a lot of splatter as I'm sure you can tell, but with the proper control it beads pretty decently to.
And yeah, tell me about the snow haha. I got a fuuuuckccking piece of metal in my eye that wont come out witha Q-tip nor a high power magnet. soooo I will be taking care of that tomorrow.
oh and it's 18gauge mild steel for the piping, decently thick so I had some oops room, no fear of burning through
Old Feb 9, 2011 | 07:49 PM
  #117
260zturbo's Avatar
I would get your eye checked asap
Old Feb 9, 2011 | 08:00 PM
  #118
evandubya's Avatar
Primer Grey FTW!
ouch! check where it attaches to the log every once in a while for cracks. steel and cast are difficult to weld without cracking. there are rods that are made for it, but 7018 works if you pre-heat to 400 degrees weld it and then peen the weld so the crystals form erratically instead of lining up.
Old Feb 9, 2011 | 08:15 PM
  #119
You know that the ZX manifolds are cast steel right? not cast iron?
and yeah it kinda hurts... The ER and urgency care won't be helpful so I am going to the eye doc first thing tomorrow.
Old Feb 9, 2011 | 08:42 PM
  #120
evandubya's Avatar
Primer Grey FTW!
okay, cool, I did not know that!
Old Feb 9, 2011 | 08:50 PM
  #121
yup! I found that little eater egg out by accident researching some other stuff, I was super stoked when I came across that.
Old Feb 12, 2011 | 04:54 PM
  #122
UPDATE!!!! motor and trans are in. Enjoy the pics of how everything sits snugly yet perfectly. I will have to make a heat shield or blanket for the exhaust manifold since I am an idiot and forgot to get heat wrap and just slapped it all together.DAMNIT ALL!!!!
btw, I know I should know this, but auto driveshafts won't go into a 5spd trans will they? I think the diff will have to get dropped... effin-A!!!
Such a sleeper this car will be
no engine
but there it is!
in she goes! that turbo is the biggest round object on the car, haha, bigger than the crank damper
waste gate dump tube and turbo allowing the steering shaft to snake just perfectly inbetween it all
so yeah, auto drive shaft from a S30 won't go into a manual trans of any sort huh? different spline count I am guessing?
Old Feb 12, 2011 | 06:15 PM
  #123
260zturbo's Avatar
pretty sure it wont fit bc of length difference possibly spline.
Old Feb 13, 2011 | 09:56 PM
  #124
well didn't achieve much today, I got the trans up and mounted so that the engine was finally level, with it raised into place I found out my dump tube was point straight at my tension control rod hahaha. So I pulled it off cut it at a shallow angle, 180'd the piece and welded it back one and viola! perfect angle pointing straight at the ground, and I extended it a little flush with the frame rail height. I also found out I just don't have a proper drive shaft!!!! I have 2 280Z auto drive shafts, a 240Z auto driveshaft, and the WEIRD WEIRD s30 manual drive shaft that is thicker that all the others and has a bigger yoke flange. So it wouldn't bolt to the normal R200 flange. I am kinda pissed. Anyone got a manual driveshaft lying around they want to donate, non 2+2 obviously? haha.
I also welded up my downpipe/O2 housing, prefect wrap around the trans and very shallow bends. then I peered into the car and notice that the fricking shifter cutout is different on an auto car! IDK how the auto cars have the studs and hole cut for a clutch master cylinder and has the bar in it for the clutch pedal, but then has these dumbaaasssss differences.... anywho... pics
Old Feb 14, 2011 | 07:42 AM
  #125
260zturbo's Avatar
Looks like u gotta do some trimming on that trans tunnel to be able to shift.... Thats odd.
