240Z, 260Z, 280Z Motor Swaps (non-V8) L28ET RB SR KA VG VQ 2JZ etc....
240z long block swap q?
Old Feb 4, 2010 | 12:14 PM
Danabolic's Avatar
PLease bear with me as I am new to the Z car scene. I bought a bucket of crap 1973 240Z that I am gong to rebuild. I have never worked on a Z cars just VW's so I know zilch.
I wanted to know if I can purchase a 280Z or ZX and use the long block from that car and will everything bolt on without any problems.
Any links etc. for parts at reasonble prices would be appreciated.
Thanks
Dan
Old Feb 4, 2010 | 12:27 PM
BlueKitsune's Avatar
Intrawebz Wizard
Thanks
Dan
Hi and Welcome to Zdriver!
As for swapping engines you can use any year Z that still uses the L engine (Straight 6) in any other Z along with their transmission usually.
Old Feb 4, 2010 | 12:48 PM
skib's Avatar
This facepalm's for you!
The 70-83 share the same drive train for the most part. 99.9% bolt in
Old Feb 4, 2010 | 01:36 PM
i would use the proper head though from that other Z long block. and just slap the carbs on them. i'll bet those carbs need a rebuild though as well.
Old Feb 9, 2010 | 09:49 AM
theramz's Avatar
I have a present for you...
You need to decide what your budget will allow. Even the latest zx L6 engine is 27 years old. You might as well rebuild the one you got. If your car is a late '73 you might have flat top carbs (nfg) unless you want to keep it original get the dome tops. I have seen many blocks that only need hone, rings, bearings and a polish on the crank. Have the head done and for $500 you got a fresh engine. Good luck!
s14kouki10
Sep 1, 2014 07:21 PM
ooms9883
Jan 15, 2014 10:18 PM
matthewz31
Sep 15, 2008 04:54 PM
300zx1717
Aug 5, 2005 07:08 AM
lukeduke95
May 5, 2005 09:02 PM
