Brakes failing after rebuild
Old Mar 30, 2012 | 03:36 PM
Turbo Biscuit's Avatar
I searched the forums and didn't find anything. I rebuilt the front brakes recently with new calipers and pads. I bled the calipers pretty thoroughly, however I just took it for a test drive and there was no brake pressure. I had to yank the ebrake to stop at a stop sign. I can pump the brake and build up some pressure but as soon as I'm done braking, the pressure goes away and the pedal goes to the floor. A vaccum hose to the booster was loose so I tightened it but still had the same problem.
Is this a problem with the brake booster? I see bleeders on the master cylinder, should I have bled from there too? There are no line leaks.
Old Mar 30, 2012 | 04:02 PM
icice9's Avatar
Super Siver & Black Stud
sounds like your master cylinder is going out.. if it were your brake booster, your pedal would feel really hard....
Old Mar 30, 2012 | 07:54 PM
You didn't bleed the master? I suggest starting with that.
Old Mar 30, 2012 | 08:57 PM
I talked to my dad and he was thinking we might have introduced air into the line. We both looked up on two different occasions and the front reservoir was empty. We'll bleed them, starting with the master, and see how that works. If it doesn't fix it then I guess I get a new master cylinder! Thanks for the replies.
Old Apr 1, 2012 | 08:00 PM
Found the problem. 2 left brake calipers! Thanks oreilly! I have to go in tomorrow to meet with the manager to see if he'll take one back even though it's painted blue. They have good customer service at this location so I think it'll work out ok.
Bruno Figarola
Oct 2, 2014 12:49 PM
ricksilvia
Sep 30, 2012 05:37 PM
onerudebuddha
FS: 300ZX (90-96)
Sep 23, 2007 12:48 PM
Tony G
Jul 22, 2003 12:54 PM
davidnet
May 13, 2002 11:02 PM
