Who makes this Hood Vent?
http://www.bleachgarage.com/images/e...08100_6651.jpg
I have one of these on my car and it is in bad shape. I like the look of it and I was wondering who makes it?
If I am looking at the picture right, that is the Nissan vent that was used on the 260Z to 280Z to combat the fuel boiling problem the Z had back then. They had it listed in the last racing parts book I got from them. It was an option for the cars then. Don't know if you can still get it from them. Good Luck, Rich.
Yes, we are talking about the same thing. It is called the Z competition hood vent introduced: dated 12-13-1974, Part Number # 99990-00182. It came out as a field fix in a technical bulletin from Nissan to cover the underhood heat from the exhaust system of both the 240 and 260Z. It was mostly for the old flat top damper-pot carburetors (boiling of fuel in the carbs). Don't know if you can still get it from the Nissan company anymore. But you can always check and see. Good Luck, Rich.
You can also go to and read the following article: WWW.Zhome.com and then go to the Z-Technical Libary, Look under Documents (index of technical articles), go to the General Discussion Area from there go to the second article starting with 1973 Dealer Modifications. Then go to the section called "Meanwhile back at dealership @#%*+%#*!" drop down to additional measures taken #4 and click on competition hood vent to see the write up by Carl Beck. Hope this helps.
Thanks that was a lot of help.
I had no idea it was a nissan part or that it was rare.
I am gonna pick up a fiberglass repair kit and patch up the chips. Someone bondoed it to the hood and most of it cracked off. Should I make it flush with the car with fiberglass? If I do will It crack off like the bondo did?
You can glue it to the hood with panel adhesive available from MSA. I would take the car to an automotive paint supply stoe and show them what I want to do. They always have someone willing to help in my experience.
You can use short strand fiberglass or long strand fiberglass and it should hold without cracking. You can also use the above message #7 and use glue to keep it in place. I have used some of the new 3M glue with a lot of success. Find a store around there that sells Auto Body material (perfered 3M) and tell them you need to attach fiberglass to metal with the glue. They should be able to give you the right kind. It will work pretty good. Good Luck, Rich.
tonsoffun300zx
34
Mar 9, 2011 12:15 AM
240z, 260z, 260znissanhoodvents, 280z, 9999000182, attach, boiling, car, fiberglass, fibreglass, fuel, hood, nissan, s30z, vent, vents
