rust patch :)
Old Jan 14, 2014 | 04:51 AM
gus280z's Avatar
rust patch :)
So, i notice that i had a little whole on the driver floor pan, the previous owner had already patched the front part of the pan, now i have to patch the mid part of the pan, eventually ill have to replace the whole pan and the rail, but in the mean time this will do.
Old Jan 14, 2014 | 06:52 AM
I dig!
Old Jan 15, 2014 | 12:24 AM
zxguy1986's Avatar
Looks right to me. Can I ask if there was any Bondo or filler involved - and also what are those fasteners and how do they work? Did you have to pre-drill the plate for them? Thanks a lot - in advance.
Old Jan 15, 2014 | 07:26 AM
Body filler is for the outside body panels to get the surface / body lines correct. For floor pans you just use hammers and dollies (and various other objects) to recreate the needed floorpan contour. You can rivet them in place, then weld. Clean, prime, and coat with rock guard / undercoat.
Old Jan 15, 2014 | 06:54 PM
zxguy1986's Avatar
Rust hole repairs
Thanks, Nismo! Gotta do this behind driver's seat in my 86NA. It never leaks up from below even during heavy rain driving but you can see the rusty pan parts from the side. Turns buyer's off. Figure I'll have to remove the seat to pull the carpet back and put the patch metal in. Riveting should work.
Don't think I can do anything with the rust under the tool kit block. It's a holey mess I patched temporarily with filler and glass fabric but the relay lever for the rear hatch/fuel door latch is rusted and there's not enough steel left under it to grab the screws for a replacement. Guess the only way to repair that is to cut out the floor plate and weld in a replacement floor section from a recycler.
Old Dec 30, 2015 | 07:38 PM
zzznuts's Avatar
Always consider using some "panel bond adhesive" for metal repairs. It is easy to use and does not require welding and can be just as strong or stronger than welding. Does not allow for corrosion on the backside like welded panels. Here is some that can be used with a standard caulking gun, where some panel bond requires a special dispensing tool.
https://zcardepot.com/tools/panel-bo...pair-8-oz.html
ETHoward
14
May 12, 2015 01:03 PM
PredatorZ
Jan 24, 2012 06:37 AM
master300zx
Apr 10, 2006 08:50 PM
espi
Nov 23, 2005 06:10 PM
Spak339
Apr 5, 2004 02:42 PM
