Door window frame weatherstrip (outer)
Old Nov 14, 2010 | 07:47 PM
dankfrye@charte's Avatar
I just received my outer door window frame weatherstrip from MSA. The parts that I received do not look like the ones that came off the outer window frame. I'm not sure this is the right part even if it is roughly the same width and length. Pic 1 and pic 2 are the same piece bent double. Pic 1 is the new and pic 2 is the old. If you notice, however, the new one is shaped like a triangle and the old one is a little more square. Can anyone tell me if these are the proper aftermarket replacements? Here is a pic of the old vs the new.
Thanks alot
Dan
Attached Thumbnails Door window frame weatherstrip (outer)-dscn0846.jpg   Door window frame weatherstrip (outer)-dscn0844.jpg
Old Nov 16, 2010 | 05:53 AM
theramz's Avatar
I have a present for you...
I just replaced mine and they are the same as you have. A definite improvement over the original. This area is a source for a lot of wind noise.
Old Nov 16, 2010 | 07:28 PM
Thanks! They seemed like they would work ok. They were just different.
Old May 21, 2011 | 01:00 AM
greenzee's Avatar
door sash weatherstrip
the way it looks, i think we have the same part which i got from motorsport auto. just installed the left side and worked fine. door closes tight. will install the right side tomorrow and have the windshield w'strip done by a friend.
Old May 21, 2011 | 05:49 AM
I have mine on also now and it works good. Glad yours worked out.
Mike Phillips
Oct 1, 2021 12:34 PM
Stukinit
Jun 24, 2013 03:26 PM
houlis1211
Feb 9, 2013 04:10 PM
Goofyz
May 15, 2007 12:16 PM
Brawley
Nov 16, 2005 02:21 PM
