CV Differential swap
Old Aug 23, 2010 | 03:59 PM
I'm planing on doing a turbo swap on my S130 - I have everything but it will likely be a winter project. I have a Turbo rear end with the CV but IIRC the diff is 3.545 and my '83 NA is 3.9 Can I swap the guts from the u-Jointed diff to the CV? I'd like to keep the 3.9 if I can as I'm running the 280b tranny that came in my '83 and its not geared as low as the T5. Couldn't find any info on the swap.
Old Aug 23, 2010 | 06:18 PM
The external measurements and the spline counts for the shafts are the same for all long-nose R200's.
Old Aug 24, 2010 | 03:38 PM
OK I'm confused. I have a 280ZXT diff/cv set up I would like to install in my 280ZX NA. It has the 3.545 ratio. I want to know if I can change it to a 3.9. The 3.9 I have from my '83 280ZX NA has outputs for a u-joint. Can you use parts from the 3.9 to upgrade the 3.545? I want to convert from u-joints to a CV rear end.
Old Aug 24, 2010 | 04:41 PM
Nismo means that so long has their both R200s, you can yank out (yes yank or pry w/e) the CV shafts and stab them into the other one with no issues.
Old Aug 24, 2010 | 04:57 PM
OK I'm still missing something here. The bolt patern on the companion or output flange on the diff is different between the u-joint version and the CV version. Do you mean pull the output flange from the 3.545 and stick it in the 3.9 then the CV half shafts will mate up?
Old Aug 24, 2010 | 06:20 PM
Yes pull the flanges out and swap them, their just held in with C clips if I remember right, so pull out the old, stab in the new till it clicks into place and your all good.
Old Aug 24, 2010 | 06:27 PM
To convert to/from halfshaft/cv axles you have to pull the wheel hub flanges too... no big deal if you have a hub puller.
Old Aug 24, 2010 | 06:34 PM
the diff flanges on the side just pull out (maybe a slide hammer, but usually 2 prybars). then install the cv's. a quick push or pop installs them. you then need the hubs with the correct bolt pattern for the other side at the wheel bearings.
Old Aug 24, 2010 | 08:48 PM
Awesome - thanks guys!
dan4227
Jun 6, 2012 02:14 PM
ezramoore
Jan 21, 2008 08:22 PM
MikeZ
May 10, 2007 01:06 PM
bardabe
Oct 6, 2006 07:13 PM
OlderThanMe
Mar 9, 2004 10:27 AM
