240Z, 260Z, 280Z Motor Swaps (non-V8) L28ET RB SR KA VG VQ 2JZ etc....
EFI and ignition setup L28et Swap
Old Feb 5, 2009 | 05:39 AM
only n00bs need their hand held for this swap. the hardest part is pin-pointing FOR SURE the exact wires on the harness you need and then labeling them what to attach them to. easy as pie
Old Feb 5, 2009 | 07:07 AM
Originally Posted by duowing
Any word on your swap Nismo?
School & work have me busy till about 8pm every night, so weekends are all I got now.
Last Saturday I got the turbo motor pulled from the donor & now I gotta get to work refreshing it. Come spring I will freshen up the S30 engine bay & do the wiring harness.
So for now I'm going to de-web the turbo intake manifold, tear down the motor, get the head machined, and make it all look pretty!
Old Feb 8, 2009 | 07:08 PM
Ratfink's Avatar
Hoov for Pres!
Haha. This has been a fun thread.
I created the wiring harness that is in my 260Z. Been removing the harness from under the dash of the '81 ZXT today, and I pretty much figured it was going to be easy. Still not worried. I am doing mine a little more custom than most though when it comes to the wiring.
Old Feb 23, 2009 | 01:09 PM
okay this thread isn't officially dead... i'm back in school and i'm just shopping for parts so i can throw it all back together when i get back. Here's my question though...
Now that i've wired pretty much everything except the injectors, i have the fuel pump relay but i dont have any ignition relay male part.
should i buy an extra one of these?
I only have one of these male plugs already (on the fuel relay portion) but i have 2 seperate female plugs (fuel relay and ignition relay as seen previously in post).
Old Nov 14, 2009 | 04:18 PM
I'm 99% ready to temp install the turbo efi harness, but I have some wiring questions for those who have done this swap:
#1: Where under the 280z dash is the wire to the stock tach? Color?
#2: Did anyone use the stock 280z 4 pin plug (next to the fuel pump relay plugs) to tap into the ignition wires and +12v wire for the fuel pump? This seems a lot easier than running new lines, since it's all right there.
And that is it! I will be creating a how-to thread for this, with CLEAR and EXACT pictures with NO confusion. I will also be upgrading the harness to a Z31T ecu & will later include those pics as well.
Old Nov 14, 2009 | 11:09 PM
that stock tach wire runs up under the hood to where the old coil was i dont remember which wire it is though
Old Nov 14, 2009 | 11:11 PM
At the coil its a blue wire I believe idk if its the same all the way to the tach but it wouldn't be shocking
Old Nov 15, 2009 | 12:22 PM
and also if you use the wire from the coil it will keep inline the resistor they have under the dash somewhere for the tach.
Old Nov 15, 2009 | 01:27 PM
my inline resistor was by the huge junction box by the passenger side kick panel. of course mine isnt working right now...i just ran straight new wire for the fuel pump. me <--noob
Old Nov 15, 2009 | 02:39 PM
I may do that. From the wiring schematics, it looks like the tach wire is the blue one (single connector about a foot from the 280z ecu plug). I just wasn't sure if it ran to the tach because the schematics just show it going straight to the neg coil terminal.
Apparently you haven't hooked it up right then. There shouldn't be anything on the passenger side for the tach.
Old Nov 15, 2009 | 02:55 PM
didnt I say blue wire? >.>
Old Nov 15, 2009 | 03:03 PM
I was referring to your comment, I just didn't emphasize it.
Old Nov 15, 2009 | 10:17 PM
skittle's Avatar
Taste My Rainbow
yes its the blue wire, and yes I ran my fuel pump and ignition to that 4 plug under the drivers side dash. It also powers my radio and boost gauge light. Nismo you should have gone with Megasquirt... So much easier to install than the stock wiring or the Z31 setup. I have mine tuned pretty well and have set the boost to 10psi. I have an intercooler that will go on soon but that will be after I dyno it this weekend.
Old Nov 15, 2009 | 10:22 PM
^^^ Right on! That's good info!
The reason I'm going w/ a Z31T ecu setup is because I already had all the parts and know how for this budget build (vs $300-$600 and tons of time to tune).
I may one day do a MSnS setup...
Old Nov 15, 2009 | 10:41 PM
skittle's Avatar
Taste My Rainbow
If you have any questions you know who to ask. Pm me and I'll send you my number.
Ryan95i4
Sep 30, 2013 06:13 AM
taylor76zharris
Oct 10, 2012 11:26 AM
slownrusty
Mar 4, 2012 05:47 PM
flatblack
Sep 3, 2010 07:51 AM
Echo Alpha
Jul 18, 2006 09:43 PM
