1986 z31 turbo ac condenser fan
Old 08-31-2015, 12:00 PM
Mike Kwon's Avatar
any members been thru fixing ac condenser fan?
here is what i have checked so far.
1. fuse is ok
2. relay is ok
3. water tem switch is ok
4. ground at condenser fan motor is ok
5. fan motor is workinf ok (direct 12 volt supplied)
6. found open wire from relay to fan motor connector.
7. found open wire from water temp switch to relay.
should i just connect fan motor direct to ac compressor clutch?
my z was getting hot one day with ac on (outside temp was 103).
if i turn the ac off then engine temp drop to normal.
i was thinking because of malfunction of ac condenser fan cause the over heating problem.
any body had this symptom to your turbo z (mine is 1986)
help need it here .
thanks for reading.
mike
Mike Kwon is offline
Old 08-31-2015, 12:45 PM
I would start with fixing these two wires.
NismoPick is offline
Old 09-02-2015, 03:17 PM
Zuphoria's Avatar
That fan will only kick on when you car reaches a super hot temp. Ive only seen mine come on like once, but i do alot of night driving.
Zuphoria is offline
Old 09-14-2015, 02:42 PM
Mike Kwon's Avatar
replaced all the wiring for the ac fan.
and also replaced the ac condenser switch.
and the fan kicks in with when temp reaches 210 or 22o with the ac on.
Old 09-14-2015, 04:09 PM
Zuphoria's Avatar
so you fixed it?
Zuphoria is offline
Old 09-14-2015, 04:35 PM
Mike Kwon's Avatar
Yes it's fix and works fine now.
I can ac condenser fan kicks in.
TigroGT
10-20-2014 06:33 PM
Spurs212095
06-05-2012 10:02 AM
z_man365
01-16-2012 09:11 AM
83Turbo
05-19-2010 05:37 PM
MR300ZX909
06-09-2004 12:49 PM
Quick Reply: 1986 z31 turbo ac condenser fan
