Transmission problems
was the fluid dark ,smell burnt? i would ask what the stall speed is but you may take out the clutch all the way only do it once if you do 2-3 seconds
I think 88 still has a governor
where is it leaking ? torque con. bushing worn can cause conv. to drain down & leak Autos gets complicated quick
if it isn't full of fluid it could . it can't get the impeller up to speed .
I filled the torque converter with fluid before putting it on. And the fluid is clean and coming from the front of the bell housing. I am thinking the torque converter has a small crack because the fluid drips when running and pours out when the engine is cut off. I had a Chevy truck that did the same thing and it was the torque converter leaking. And as for the shifting and now a slight shutter sometime a when it need to shift I no idea what it could be.
There is usually a 4-5 day course for auto trans repair ,I' m just saying
The transmission is Alined. Itook it to a guy I trust today and he said he thinks it's the front seal or the torque converter and that the problem changing gears is most likely the bands need adjusting or replaceing. Does that sound about right to you?
AkumaZeto
08-24-2016 10:58 AM
