Crank timing sprocket removal, please help
Hello and thanks for all your input on this forum.
I have 1985 300zx na 2+2
I will be drilling and tapping and then pulling the crank timing sprocket.
2 questions....
Do I pull the sprocket over the woodruff key or pull the woodruff key first?
After I drill and tap the crank sprocket can I reuse it?
THANKS!
Jim
2 questions....
THANKS!
Jim
You pull it over the woodruff key, you can't remove the key unless its showing more than half. I would use a new sprocket for sure. Soak it in penetrant or something for a while first, easier to remove.
