Koyo radiators
Old Jan 23, 2007 | 05:41 PM
i8acobra's Avatar
Koyo radiators
Anyone have any experience with them? Do you think I should go with a 36mm or 54mm unit?
Old Jan 23, 2007 | 10:42 PM
SinCity350Z's Avatar
Las Vegas Moderator
The bigger the better, but also the more pain in the *** to install . If you aren't planning on tracking the car, I think you can get away with the stocker, but if you must get a radiator you should be fine with the smaller of the two. Any track time though and I would go for the bigger one.
Old Jan 23, 2007 | 11:17 PM
Stealth's Avatar
One more thing if you have alot of hp over stock, it a must to have a bigger radiator to drive on the street.............especially in las vegas.
Old Jan 24, 2007 | 10:46 AM
Love2ridepow's Avatar
X1000, last summer I was very close to overheating several times just playing around.
Old Jan 24, 2007 | 10:47 AM
Las Vegas Moderator
Well turbos generate a lot more heat than superchargers do as well.
Old Jan 24, 2007 | 11:00 AM
roneski's Avatar
Actually I've found that the vented hood helps out alot. I get on it pretty good around town and don't really have any problems.
Old Jan 25, 2007 | 12:24 AM
i8acobra's Avatar
I'd go with the 54mm unit, but I'm trying to find out if the stock fans will still fit. I'm pretty sure I'm going to need a bigger radiator, I just don't know how hard it is to make the 54mm unit work, or should I just go with the 36mm unit?
What are you running Mike?
Old Jan 25, 2007 | 09:36 AM
Las Vegas Moderator
I am pretty sure I am running the 56mm with stock fans. It was seriously the biggest PITA to install because of the tight fitment, but it does work.
Velox ZX
Oct 12, 2005 11:00 AM
juggalo280ZX
Jul 3, 2005 08:36 PM
SinCity350Z
May 25, 2005 10:49 PM
chef_tickwon
May 15, 2003 05:51 AM
GodZilla
Jan 21, 2002 03:09 PM
