Finally installed my Test Pipes
Old May 7, 2006 | 07:31 AM
Love2ridepow's Avatar
So after a few times under the car and a few trips to Sears for some more tools, I finally got my test pipes on. It only took me about 2 hours once I figured out how to get to all the bolts, which really was not as hard as it originally looked once I got the right tools. My Z is DEFINATELY faster. My butt dyno says I gained at least 20whp. The sound is a little loud, but I am sure I will get used to it. I used to be able to get through 3rd gear without slipping the tires too bad, now I am slipping the tires in 4th a little and I have no gripping 3rd gear. Now I need 2 things, wider tires and a fender roll. I am pretty sure I can squeek 315's on my 9.5's, anyone know of a place to get my rear fenders rolled? I am not going to tackle this one myself.
Old May 7, 2006 | 05:49 PM
rob209's Avatar
sweet... might as well get DRs cause I doubt the extra width will take care of all that traction for you.
Old May 7, 2006 | 06:51 PM
turbo_jimbo's Avatar
sounds like its time to turn the boost down for daily duty.
Old May 7, 2006 | 09:40 PM
Nforce1's Avatar
there goes street legal though..
Old May 7, 2006 | 11:09 PM
SinCity350Z's Avatar
Las Vegas Moderator
What offset is your wheel? 315s will fit on a 18"x 9.5" without rolling the fenders if they are a +30 offset.
Old May 8, 2006 | 07:52 AM
I am not 100%b sure, but I think I remember them being +23. I don't see how that would work because right now the edge of my tirews sit right under the edge of the wheel well.
Do you have VDC Mike?
Old May 8, 2006 | 08:44 AM
Las Vegas Moderator
Yeah +23 would not work. I do have VDC, but it is always off.
Old May 8, 2006 | 02:03 PM
rob209's Avatar
yeah his Z is much quicker and the boost is getting over 10psi now, should be a very interesting race this Wednesday night...
Old May 8, 2006 | 02:10 PM
roneski's Avatar
10psi? Is he on stock internals? How much boost do you run Rob?
Old May 8, 2006 | 02:23 PM
10+psi is what my Zietronix is "quoting". I think because I have not changed the elevation settings from when I was in Utah, its a little high. Yes, I am on stock internals and the APS stock tune.
Old May 8, 2006 | 03:51 PM
rob209's Avatar
Mine creeps over 11 around 4k, then tapers down to 8psi from 5k to redline.
luis88
May 11, 2010 05:40 PM
nka04a
18
May 20, 2006 03:50 PM
iminsideurZ
30
Sep 12, 2005 10:57 PM
typeaproduction
27
Feb 28, 2004 04:01 PM
John300
Oct 19, 2002 06:44 PM
