Finally installed my Test Pipes
So after a few times under the car and a few trips to Sears for some more tools, I finally got my test pipes on. It only took me about 2 hours once I figured out how to get to all the bolts, which really was not as hard as it originally looked once I got the right tools. My Z is DEFINATELY faster. My butt dyno says I gained at least 20whp. The sound is a little loud, but I am sure I will get used to it. I used to be able to get through 3rd gear without slipping the tires too bad, now I am slipping the tires in 4th a little and I have no gripping 3rd gear. Now I need 2 things, wider tires and a fender roll. I am pretty sure I can squeek 315's on my 9.5's, anyone know of a place to get my rear fenders rolled? I am not going to tackle this one myself.
Originally Posted by 350ZNV
What offset is your wheel? 315s will fit on a 18"x 9.5" without rolling the fenders if they are a +30 offset.
I am not 100%b sure, but I think I remember them being +23. I don't see how that would work because right now the edge of my tirews sit right under the edge of the wheel well.
Do you have VDC Mike?
Originally Posted by roneski
10psi? Is he on stock internals? How much boost do you run Rob?
10+psi is what my Zietronix is "quoting". I think because I have not changed the elevation settings from when I was in Utah, its a little high. Yes, I am on stock internals and the APS stock tune.
