30,000 Mile Service
Old Dec 15, 2005 | 11:21 AM
Nforce1's Avatar
30,000 Mile Service
Do you guys think I should spend the $200+ on the 30,000 mile service?? Or just do everything at a tech session? What would be the disadvantage of doing it all at a tech session, other than for warrenty issue. We should be able to handle everything that is suggested for the 30K service. Comments/Suggestions appriciated!
Old Dec 15, 2005 | 11:46 AM
SinCity350Z's Avatar
Las Vegas Moderator
Whats all included in the 30k service? I am sure we can handle it.
Old Dec 15, 2005 | 12:23 PM
Nforce1's Avatar
30,000 Mile Service or 2 Years - $289
- Change Engine Oil
- Change Engine Filter
- Inspect Engine V-Belts and Adjust
- Install BF Fuel & Oil Additive
- Inspect Coolant Hoses, Connections, Clamps & Tighten
- Inspect all fluid levels
- Check Tire Pressure
- Lubricate Latches and Hinges
- Check Engine Ignition Timing
- Inspect Front Disc Pads
- Balance Tires and Rotate
- Inspect Steering Components & Drive Axles
- Replace Air Filter
- Replace Spark Plugs
- Replace Fuel Filter
- Inspect Rear Wheel Bearings
- Cleans, Inspect and Adjust Rear Brake She and Emergency Brake
- Test Air Conditioner System Performance
- Test Battery, Charging & Starter System
- Inspect All Lighting
- Install BF Battery Ternial Protectors - Clean Terminals
- Road Test
- Multi Use Test on Computer System
- Throttle Body Service on Models 2000 and Newer
In Cabin Air Filter Recommended
-RECOMMENDED : BG Coolent Service
-RECOMMENDED : BG Transmission Service
Damn that was a lot to type!, I couldnt find it on the internet!
Old Dec 15, 2005 | 12:30 PM
VegasEdge's Avatar
WTF So they change Engine Oil/Engine Filter/Spark Plugs/Fuel Filter/Install BF Battery Ternial Protectors? For 289$ lol
I think thats a joke.... Unless your z is falling apart and have no tech skill at all i guess it would be ok....
Old Dec 15, 2005 | 12:39 PM
Nforce1's Avatar
Basicly!! lol...
Old Dec 15, 2005 | 12:54 PM
rob209's Avatar
what's an engine filter?
Old Dec 15, 2005 | 12:55 PM
rob209's Avatar
I noticed my belt is looking kinda worn - isn't that one long belt?
Old Dec 15, 2005 | 01:09 PM
Las Vegas Moderator
Oil filter.
Aarif...judging by that list, its well worth the $289.00.
Old Dec 15, 2005 | 02:00 PM
Nforce1's Avatar
Yeah, but you know they only do like.... 5 of those things.
Old Dec 15, 2005 | 02:16 PM
Las Vegas Moderator
Thats true, but I just don't want to change your spark plugs lol.
Old Dec 15, 2005 | 02:53 PM
roneski's Avatar
Plugs are a bit of a pain, but it's doable.
Old Dec 15, 2005 | 03:17 PM
ensmuns's Avatar
Vegas 350Z Moderator
Yeah, I'd spend the $289. There was a coupon pack that was sent out by Nissan a few weeks ago. It had 15% off on parts/service. Total would be $245 + tax.
Old Dec 15, 2005 | 10:59 PM
Nforce1's Avatar
Well I got it all done for free.... but, go figure.. I just asked my friend and they didnt change the spark plugs. Still need to do that, but everything else was done.
Old Dec 16, 2005 | 12:01 AM
turbo_jimbo's Avatar
hold on.... on the z, all you need to do is change the oil and filter, change air filter, clean battery terminals, and other suggested items may include, tranny service, rear diff service, and coolant service. beyond that all you need to do to maintain the warranty would be change the oil every 3750 miles. spark plugs need to be changed at 105k, and rear diff make sure to use lsd gear oil, and the tranny fluid is expensive, but make sure you use the right stuff!!! no one can alter the timing on the stock computer, so checking it is poitless... a lot of the stuff on the list is just there for the old cars and for stupid people.
Old Dec 16, 2005 | 12:02 AM
oh, and balancing your tires is reccomended but DO NOT rotate them.
Old Dec 16, 2005 | 12:36 AM
Las Vegas Moderator
^^^He has staggered 19s now anyways.
Old Dec 16, 2005 | 09:13 AM
vegas_speedster's Avatar
Warranty what warranty?
Old Dec 16, 2005 | 04:24 PM
KENNYZ's Avatar
"I don't need no stinkin warranty" Wait a minute, yea I do.
Or at least save your stock parts.
Old Dec 16, 2005 | 05:58 PM
ensmuns's Avatar
+1 on that.
gridez31
Sep 8, 2011 07:04 PM
Turbo86
Jun 5, 2006 01:07 PM
bardabe
Dec 12, 2004 09:43 PM
pearly whites
Sep 1, 2004 02:21 PM
AllmyZs
Sep 13, 2002 07:38 AM
