Site Feedback and Suggestions If you have any suggestions or want to see something voice your opinion in here.
280zx not turning over
Old Feb 17, 2019 | 01:53 PM
DvLZ83's Avatar
I did a head gasket job on my n/A 1983 280zx and have no compression on all cylinders. I changed a lot of components already and doubled checked my timing. Fuel pressure is around 33 psi, and I have spark. Components that I changed so far:
- Distributor, Spark plug wires, Ignition coil, ICM, ECU, Ported vacuum switch, starter, vacuum lines, air filter
Components that I checked:
- Timing at camshaft sprocket at number 1 marking and crankshaft marking at piston #1 at TDC, fusible link which is battery voltage, fuel pump relay (all 3 relay are good), fuel pressure is at 33 psi, 0 psi on all cylinders
Just don't know what the problem is. To me it seems like there is no vacuum pressure going into the combustion chambers. I attached a link here at youtube for viewers to see what I'm talking about.
Let me know what you guys think because I'm out of options at the moment.
WylieCoyote88
Site Brainstorming
Aug 6, 2017 10:57 AM
Jaredfossek
Site Brainstorming
May 4, 2017 08:14 PM
thetremendousti
Jun 18, 2009 10:45 PM
Niku-Sama
Dec 18, 2008 11:04 PM
