Motorsports This board is for Z Racers who compete in Autocross, Road Racing and Time Trials. Focus will be on car set up and modifications. Event coverage, and race parts for sale or trade.
Ideas on clutch/flywheel combo's?
Old Mar 26, 2003 | 03:23 PM
preith's Avatar
I'm currently building a solo1 car with plans on vintage racing in the future. Pics were posted under member rides a little while back. I'm probably putting too much thought into this, but I was curious. What kind of flywheel/clutch combinations are other guys (autocross and road racing) using, or planning on using? I'm considering a Tilton dual disc setup.
Old Mar 26, 2003 | 06:03 PM
DrSideways's Avatar
I use the Tilton 7 1/4" dual disc unit. When I bought this I was still doing a fair amount of Solo II work. Going from the standing start requires the larger unit. I plan on updating to the 5 1/4" unit this season.
Now that I am doing 100% track work I want the 5 1/4" setup. The smaller diameter gives you a lower Moment Of Inertia (MOI). A lower MOI puts less stress on the crank. It makes the car accelerate like it has a lower gear. The transmission will shift easier just like adding a light flywheel does, only better.
So if your parking lot days are done, get the small unit.
Alan
Old Mar 27, 2003 | 07:56 AM
preith's Avatar
What kind of flywheel are you using with the 7 1/4"? I haven't been able to find any manufacturers that make a standard diameter flywheel which allows you to use the stock starter. Malvern makes a smaller one which requires his "special" starter. This looks like the way to go, even though he's pricey. Also do the 5 1/4" units noticeably wear faster? If so, in what relation to the larger unit? Interested in selling your 7 1/4" setup?
Old Mar 31, 2003 | 04:27 PM
DrSideways's Avatar
Preith,
If you would like to see about getting this 7 1/4" setup with the stock diameter flywheel you need to email me @ DrSideways@aol.com ASAP.
I am making some changes and I may be going ahead to the smaller unit if you want this one.
Thanks,
Alan
sticky280zx
Mar 10, 2008 11:28 PM
allmotor300z
Feb 3, 2005 07:07 AM
tsefreeflow
May 15, 2004 11:30 PM
Darylick
Oct 28, 2002 08:10 AM
