how to polish !! SAVE MONEY !!!
Old Feb 10, 2006 | 06:50 PM
nismo619's Avatar
Smile how to polish !! SAVE MONEY !!!
Hello every body for the last few days i have been disgusted on places trying to tell me ill polish your valve cover for 300 bucks.. i laughed as i turned my back on most places here in this town, but i talked to a guy at a shop and he told me some hints... i took his advice and went to the local paint shop and bought some 600 grit 800 grit 1000 grit 1200 grit 1500 grit and than 2000 grit than used ( mothers aluiminum polish ) i bought the polish from walmart for 3.49 and u guys should see the bad AZZ job i did on one of my 280zx turbo swazzy rims ! omg it looks sooooo good ok people !!! hears the deal save money and do it yourself it took me about 4 hours per rim remember to get the ( WET SAND PAPPER !!! ) ill be posting pictures of the rims stock and litteraly NEW !!! nismo619 with new looking 280zx turbo rims !!! yaaaaaaaa!!!
p.s. valve cover is next !!!!
Old Feb 10, 2006 | 07:47 PM
Right on man, sounds great! So in what order did you use the sandpaper grits?
Old Feb 10, 2006 | 08:03 PM
nismo619's Avatar
LOL @ wild man ! well i started with 600 wet grit and took the piece of sandpapper and dipped it into a bowl of water and worked it all the way in and around the rim INCH by INCH by INCH 600,800,1000,1200,1500,2000 wet grit then i washed it all off let it dry and then put on a little bit of mothers polish on it rubed it in until it turned black as the directions say i let it sit there for about 10 min ( my hands and fingers were numb ! ) came back and rubed it off and its so shinny i can see my face in the rims !!! WOW !!!
p.s. i started with 600 grit to help remove any deep scratches / blemishes, i guess if your rims are perfect u guess u could start with 800 grit and work your way up !
p.s.s posting pictures tomorow no more sun light left.. =-(
Old Feb 10, 2006 | 08:54 PM
Right on man, thanks dude! I will try that first on my 6-spoke wheels. And then my other wheels later. Hey administrators, you should make this a sticky. Great info, on polishing our wheels.
Old Feb 11, 2006 | 12:57 PM
jmw.81's Avatar
a couple more tips on polishing:
Always rinse the surface between grits. Otherwise when you switch to a higher grit, you'll still have some of the lower grit particles on the surface which defeats the purpose of the higher grit.
Start with the highest grit you need. You can determine this by the depth of any scratches on the surface. Just start with a high grit and see if it will take the scratches out. If not, then step down to a lower grit.
And finally, polish is NOT like wax. You dont have to leave it in place. It doesn't work that way. Its just a light abrasive. Leaving it in place to dry will only make the work harder. It wont affect the outcome. Its usually recommended you DONT let the polish dry.
Old Feb 11, 2006 | 05:40 PM
gabrielzzz's Avatar
big question on the polishing of the swazi's....i have swazi's myself, you just polished the outside of it right, because the spokes have a very thin and close grouped grooves that are curved in a circle contrast to the circular rim...dont know if all that made sense, but the question is, did you sand the spokes as well, and how???
Old Feb 12, 2006 | 12:57 AM
nismo619's Avatar
i did the complete wheel !!! ok i did do the lip i did do the center section u could be able to do the groves but my big fingers wont fit inside the groves i also did polise the inside of the rim also ( by god tha tkes a long time ! ) i would only recamend doing the outside of the rim unless your like me and u are just a freak and want to see what it looks like lol my wheelz are super shinny i couldnt belive it until i did it ( I DID MY VALVE COVER TODYA TOO !!! ) oh my god u guys its so shinny the sun hit it and it blinded me !!! for about 10 seconds my darn camera is low on battery power but dont worry puictures will be posted later on this week monday hopefully , nismo619
p.s. yes do wash off the old sandpaper resadue !!!
82-280ZX
Jun 9, 2015 10:02 AM
KingDatsun1
Oct 24, 2008 07:03 PM
BlackCrow
350Z Performance / Technical
Jun 17, 2006 06:49 PM
ZLover4Life
Aug 25, 2005 01:45 PM
DarrellBuddy321
Jul 28, 2005 12:09 PM
