350 swaped with stock rear end
Old Nov 24, 2008 | 06:18 AM
280zx2by2's Avatar
Haterade by da gallon!
never have seen anyone keep the datsun multi link rear end with a v8 swap before but if it works it works
this was at the moltrie swap meet, the guy knew nothing about the car, he just bought it from a shop
Old Nov 24, 2008 | 08:09 AM
do you live in a hole or something? its VERY common to leave the stock rear end in the Z maybe add an LSD or something but the R200 can take the beating and theres nothing wrong with the suspension setup either.
Old Nov 24, 2008 | 08:20 AM
280zx2by2's Avatar
every swap i have seen (in the short period i spent there) they were all doing straight axle swaps
Old Nov 24, 2008 | 08:35 AM
Straight axles are for drag racing and off-roading (they suck for off-roading too).
Straight axles in a sports car = FTMFL. Might as well put some mudders on it too.
Old Nov 24, 2008 | 08:38 AM
unless its a quick change or multi link floating 9" as commonly used in successful american road races.
Old Nov 24, 2008 | 08:50 AM
280zx2by2's Avatar
tell that to a first gen rx7.....
Old Nov 24, 2008 | 08:59 AM
Oh no!!! Look out!!! 100hp!!! I bet a solid axle at 100mph is so nice!!!!!!
u tink if i putz a solid axel in muh geo it wood handel better?
Wait... better yet, I think F1 racecars should be fitted w/ solid axles. That would make them handle A LOT better!!!
/sarcasm
Old Nov 24, 2008 | 09:02 AM
280zx2by2's Avatar
Oh no!!! Look out!!! 100hp!!! I bet a solid axle at 30mph is so nice!!!!!!
the 1st gen rx7 i drove was faster than my zx... or at least thats the way it felt (might have just been the sound of that rotary making me think i was going fast)
Old Nov 24, 2008 | 09:05 AM
oh geez... that means YOUR Z has less than 100hp.
Old Nov 24, 2008 | 09:08 AM
i would love this in my car, but cant justify spending the $6k
Old Nov 24, 2008 | 09:11 AM
280zx2by2's Avatar
wtf what is that from? and whats the advantage of having the brakes in the middle, drag tires fitment?
Old Nov 24, 2008 | 09:13 AM
its a winters independent quick change, i know what the advantage of having the brakes that close to the diff is, but i cannot put it into words.
280zx2by2's Avatar
nope its a 2+2 GL
Old Nov 24, 2008 | 09:16 AM
nope its a 2+2 GL
1st Gen RX7's were rated at 100hp. If it was faster than your Z, simple math would show that your Z puts out less than 100hp...
Or... it could be that you have no idea what "faster" feels like.
Old Nov 24, 2008 | 09:20 AM
280zx2by2's Avatar
oh your soooo smart!!!!!! cause i guess weight has NOTHING to do with accelaration characteristics.... i fail at simple math
Old Nov 24, 2008 | 09:35 AM
http://www.rx7.org/public/1st-gen.html
http://www.zparts.com/showcase/zcars.../perf280zx.htm
RX7:
0 - 60 accel 9 - 10 secs varies with engine/trans
8 - 9 secs SE model (13B engine) [2]
1/4 mile accel 17 - 18 secs/80 - 83 mph
16 - 17 secs/84 - 85 mph (SE model) [2]
280ZX:
0-60 9.2
1/4 Mile (time@speed) 17.2@82
Old Nov 24, 2008 | 09:38 AM
280ZX weight: ~2900lbs
RX7 weight: ~2500lbs
280ZX + 20 more hp, which pulls 400lbs more....
Old Nov 24, 2008 | 09:40 AM
RX7:
280ZX:
0-60 9.2
wow, that horrible, i think one of those pocket bikes from autozone can do better
Old Nov 24, 2008 | 10:18 AM
280zx2by2's Avatar
and lets see my 280zx is a 2+2 that adds what 150lbs? GL that would have to add 30lbs at the least, and my box should add 40 lbs... the rx7 had a fully resealed/rebuilt motor and mine is as original as 81 gets, oh did i mention my t-tops?
280ZX weight: ~3150lbs
Old Nov 24, 2008 | 10:59 AM
A 280ZX running correctly should have good torque. An RX-7 with a rebuilt engine still wont' have torque.
I rode in a 1st gen RX7. It was obviously slower than my non turbo Z.
Old Nov 24, 2008 | 11:16 AM
Ratfink's Avatar
Hoov for Pres!
So wait... Solid axles suck in off road applications?
You need to be specific there man.
Or I need to go back to all the axle swaps I have done, and let them know we screwed up.
If I were to build a Baja race rig or rally, I would want independant suspension. Otherwise.. No.
To keep from getting stuck at slow speeds, it solid axle ftw.
On the street? Nah. No thanks.
Drag? Sure.
The Z is light enough that the rear end will not normally see enough torque to cause a problem. Unless you throw slicks into the equation.
Old Nov 24, 2008 | 07:14 PM
260zturbo's Avatar
Stupid Hurricanes...
iv only seen a handful of people swap to solid rear axles in a z. i guess if all they do is drag race then ok. but other then that it serves no purpose. you loose alot control with you lose your independent suspension. anyway my friend with a 383 in a 280 has a stock rear end in his z. It holds up very well just needs a better gearing 3.364
Old Nov 25, 2008 | 02:52 AM
You rode in one. But was the driver getting on it? I actually drove a first generation '85 RX7. And I will tell you right now. That sucker was friggin' quick man. No joke.....I wanted that car so bad. Heck....I got on that thing..and it was a 5 speed. And I was doing 90 pretty dang fast. And it was comfortable to sit in also. Those rotary engines...are nothing to joke about. They may not have much hp. But those little cars...are quick and light. I have drove one. And ridden in 2 others. They were all pretty fast.
Old Nov 25, 2008 | 05:54 AM
280zx2by2's Avatar
this was my feeling but as soon as you got to 100mph all hp was gone and you were just crawling to gain speed
and the top end of a zx is like 130mph or so... but it takes a while to get there
Old Nov 25, 2008 | 07:30 AM
i left the stock rear suspension as is on zach's car i just built, worked fine, even handled well too. that crazy guy even raced a porsche to 120mph!!! ive lined up against my buddies 1st gen rx7 gsl-se when we were both stock, it was pretty even to 60mph. after i did my motor i won, then he put a 425hp chev in it and it was way faster, but didn't handle nice like a 280 with the chev does.
