FS z31 na to turbo swap parts Dallas
Old 08-17-2018, 11:32 AM
tempestas's Avatar
Need to clear out some old z31 parts. I have just about everything needed to swap to a NA to turbo as well as many other odds and ends.
If there is somone local, I'll unload a whole setup for $300. (ecu, injectors, exhaust manifold, turbo inlet/outlet pipes, downpipe)
If you see something here you want or want to ask about shipping, send a PM.
88 turbo auto federal ecu
88 turbocharger and manifold and 02 housing
88t injectors
A second turbo manifold if anyone is looking for a manifold... (by the way, yes they both have some hairline cracks, no issues in use or visible leaking, standard condition)
Stock downpipe, i think this was from a 86t if i remember right
I may have a 88t wiring harness, but it likely has some hacking out of it... you don't really need the turbo harness
det sensor and plug, chopped off with some wire you can run back to ecu if you so please.
charge pipe from turbo to manifold
turbo inlet pipe
don't have a turbo crossmember... well, i do but it's hacked up, your welcome to pieces if you want.
also have a 87na ecu
also have several MAFs laying around
also have a 86t t5 trans and driveshaft
don't have any interior or suspension or LSDs
here are some half-assed pictures, will give better ones on request.
Attached Thumbnails FS z31 na to turbo swap parts Dallas-img_20180817_122210003.jpg   FS z31 na to turbo swap parts Dallas-img_20180817_122235650.jpg   FS z31 na to turbo swap parts Dallas-img_20180817_122246882.jpg
Last edited by tempestas; 08-20-2018 at 09:01 AM. Reason: removed reference to an item sold and no longer available
tempestas is offline
Old 08-22-2018, 07:39 AM
PM sent.
NismoPick is offline
Old 01-29-2019, 08:37 PM
tempestas's Avatar
lowering price... sold 1 ecu - still have the 88t turbo, manifold, ecu, downpipe, injectors
all this yours for $250 local pickup.
Old 03-19-2019, 06:33 AM
tempestas's Avatar
additional photos as requested
foxcars
09-11-2013 07:11 PM
89_300zx
12-02-2012 08:00 AM
ZLGSEABOLT
12-15-2006 03:52 PM
86300zx
07-13-2006 07:06 AM
DarrellBuddy321
04-15-2005 08:22 AM
Quick Reply: FS z31 na to turbo swap parts Dallas
