FS: 1979 280zx Phoenix,Az
Old Nov 27, 2012 | 03:19 PM
T.Holland40's Avatar
FS: 1979 280zx Phoenix,Az $3,200
The guy I got it from was getting it ready for track racing, I bought it and maintained it
Title in hand Passed smog- currently tagged and regestered
Cold start Issue- has been disconnected. I usually just give it a little gas until it warms up
Drivers side window switch is bad, window won't roll up, motor is good though
Aftermarket Magnaflow with 3 inch pipe i believe
New fuel pressure regulator
New thermostat w/ gasket
New water pump w/ gasket
I have front and rear bumper
4 speed trans was swapped to 5 speed
1.5" lowering springs installed
Interior is removed, plastic side panels present, could use replacing
Original paint- minor scratches
Original glass- windsheild has 3 inch crack in corner on drivers side
Four- 3 month old tires, Forceum's
Aftermarket radiator
Heater core removed- I have the heater core
A/C removed
Oil pan gasket was just done
Vehicle has been maintained- Including valve Lash adjust. Recently done 3 months ago
Instrument cluster does work except for speedo
Just did rear brakes
Other than that, I use this girl for daily commuter. She drives perfectly and never had a problem, other than that cold start issue.
I am asking $3,200 OBO First REASONABLE offer takes it
I can email and text pictures to you
Email T.Holland40@gmail.com or Text 602-319-6735 Thank you for reading
rocky_dogtown
Apr 6, 2014 10:34 PM
evandubya
Oct 2, 2011 06:44 PM
spdsk8r
Mar 4, 2010 09:39 PM
skittle
May 12, 2006 11:03 AM
DMacGeorge
Apr 4, 2006 05:28 AM
