Unseen Lock Issue
Old Apr 8, 2009 | 10:00 PM
Razer523's Avatar
Unseen Lock Issue
I searched and read everything having to do with power locks, and can not find a fix.
I have a 92 Z32, n/a 5spd, and Heres the deal, I can not unlock or lock from the drivers outter handle, key cylinder will turn though. Also, I can not lock the doors if a door is open, I have to hold down the door switch so the car thinks all doors are closed in order to lock them. If i dont hold it down, it will lock and then automatically unlock and sort of unlock twice. There was an aftermarket alarm which i removed completely and repaired all the wires spliced.
Any help would be awesome, thanks guys
Old Apr 8, 2009 | 10:11 PM
there might be a disconnected linkage inside the door itself for your first problem. for the second problem thats just the car smarter than you. it does that so you dont accidentally lock your keys in the car. next time, with the door open hold the interior door handle out (as if trying to open the door from the inside but with the door already ajar) and then flip the lock. should stay locked, at least i think thats how the Z's work. that or it was the outer door handle. try either way, but its just a safety feature.
Old Apr 8, 2009 | 10:32 PM
Razer523's Avatar
Thanks
A safety feature huh? Thats good to know, i got two friends with z's and would have tested it before, but one is getting nothing from his power door locks and the other re wired his for buttons.
Ill have to rip apart the door on my next day off and just search through the entire door, maybe hit pick and pull and grab some wiring to try swapping.
Old Apr 8, 2009 | 10:51 PM
couldn't hurt
Old Apr 9, 2009 | 12:13 PM
napoleonzheking's Avatar
F5 Hero
the second problem, the door should stay locked and not unlock, it will however unlock if you shut the door without holding the outter handle open while you shut the door. The second problem I would bet is related to your aftermarket security feature you removed somehow.
Old Apr 9, 2009 | 05:20 PM
thats how it worked ^^^^ my bad the way i described is for civics haha. its been a while since i had a Z32
Old Sep 8, 2012 | 04:15 PM
PulMaFinga's Avatar
Yea I am having the same problem. Just bought a 1990 Z32. Couple of aftermarket mods. One of them being a Viper alarm system but I am having an issue. The locks do not lock on the passenger side. Even when both doors are closed and I hit the clicker to lock it the alarm engages and locks the driver side but doesn't lock the passenger... Even when I go to lock the door from the inside it still doesn't lock... Anyone know why this would be happening? I am thinking the door lock wiring is bad but I don't know whats up with it right now.
Old Sep 9, 2012 | 04:27 PM
Rupe's Avatar
Horsepower Mathematician
If you close both doors and use the key to manually lock the driver's side, do both sides still lock?
bigdoggin
Jun 14, 2012 07:24 PM
BRAAP
Apr 9, 2010 01:04 PM
FubarI33t
Sep 10, 2005 10:35 PM
SinCity350Z
Jun 21, 2005 07:33 AM
CanyonCarver
Jul 23, 2004 02:58 PM
