tranny fluid
Old Jan 26, 2008 | 06:58 PM
KasbeKZ's Avatar
Pr0n Addict
tranny fluid
pretty basic question here but i was a little nervous about doing it without some back ground
i ahve the drive shaft pulled out of the transmission doing the carrier bearing. for anyone that has seen the inside of these trannys, would it sound like a good idea to stick my tube from the fluid bottle in the back of the transmission to put a little fluid in? the plug on the side is stuck pretty good and this would save the trouble of getting that out. it looks like the bottom of the tail shaft opening is just about at the same height as the bottom of that fill hole, so i could get the level very close to perfect. any ideas?
Old Jan 27, 2008 | 10:53 AM
KasbeKZ's Avatar
Pr0n Addict
nah. i can't even get the tube from the bottle into that slot. looks like i'm going to have to get the plug on the side broken loose
Old Jan 27, 2008 | 12:29 PM
should be a drain on the bottom a fill plug on the side. then run some hosing to it and fill her up till it starts to leak out of that hole (or the recomended amount which is usually where the hole is)
Old Jan 27, 2008 | 01:46 PM
KasbeKZ's Avatar
Pr0n Addict
yea i know the way that you are supposed to do it, but i can't get the plug out of the side. i'm using a 3/8 breaker bar and i had my foot on the bar and hands against the back tire and i just can NOT get it loose. i hosed it down with PB blaster so maybe tomarow
Old Jan 27, 2008 | 06:10 PM
for what the fill plug? yeah for some reason EVERY fill plug from factory is retardedly tight. so you might have to do what i ALWAYS do and make your own breaker bar. its basically the breaker bar, with my jack handle on it so its now and almost 4 foot breaker bar, just have some one hold the head of the breaker bar on the plug other wise it can start to slip out and round the square head in the plug
Old Jan 27, 2008 | 06:45 PM
KasbeKZ's Avatar
Pr0n Addict
haha i started to round it out a bit by hand with a 14 inch breaker bar. and i was holding it in. that B is tight. i certainly hope it's been out within 150K miles. factory tranny fluid in there would not make me happy. it is making a bit of sound from the front shaft. i hope new fluid smooths it out
Evan Faris
Jul 25, 2013 01:03 PM
tonsoffun300zx
Apr 15, 2008 05:52 PM
2.8.0.Z.X
Mar 26, 2008 09:18 AM
skittle
Aug 20, 2006 05:47 PM
waterdogzx
Apr 4, 2005 11:40 PM
