Tranny bell housing top bolt
Old Oct 12, 2008 | 07:14 PM
napoleonzheking's Avatar
F5 Hero
How are you supposed to remove this? i have all the others out (I think, I was told there were 10, I've only found 9 (including the one on top i can't get to) ). I have extenders and swivel, I think i might beed more extenders or something unless someone has a handy tip? I can go through the shifter linkage where the shifter is coming through if anyone has tried that before?
Old Oct 12, 2008 | 08:20 PM
KasbeKZ's Avatar
Pr0n Addict
it is a hard one. you can't even see it.
i can't get to specific, but i can tell you that i had two people. i was on top sticking my hand behind the engine to catch the socket that my dad was pushing up from the bottom (cause my hands are smaller), then i'd hold it while he cranked.
tools were a standard ratchet, one very long extension, two mid sized ones (about 7 in. i guess. i forgot all the real measurements), and 2 +-1 u-joints. i think it was the long extension, the short one, a u-joint, a short one, a u-joint, a socket. i think. something like that. good luck.
also try adjusting the jack under the tranny to see which angle helps you. i really forgot which way i liked to put it to help, but you can get the engine away from the fire wall from where it usually sits, which helps
Old Oct 13, 2008 | 06:44 AM
CanyonCarver's Avatar
Jack Of All Trades
I use about 18" of extensions and a swivel. You pretty much have to blindly reach up there, with socket in hand, and feel your way to the bolt head. My ratchet is usually down by the tranny mount. I wrap some black tape around the swivel the keep if from flopping around.
There are two bolts up there btw.
On another note, when we did my kids' clutch a month or so ago, he rounded off one of the top bolts by not having the socket on good. The bolt was on the passenger side top. We were actually able to get a box-end wrench on the bolt, then we hooked a tie-down over the end of the wrench and I was able to pull on the strap to loosen the bolt. We could then get the socket on it to uncrew it.
Old Oct 13, 2008 | 11:08 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
socket -> 10" extension -> universal joint (swivel) -> 10" extension -> ratchet
Go in from the side of the trans, about halfway back the length of the trans.
If you have stubby gear wrenches, you can use that from the top of the engine bay, too... assuming you've removed the battery and done a few simplicity mods (eliminated parts that aren't necessary).
Old Oct 22, 2008 | 06:21 PM
Shameless's Avatar
either way you try it it is not easy. Me and my dad ended up getting it with just a regular old wrench lol. He was also a jet mechanic for 15 years so working in cramped places is his specialty lol. But i do believe the guide on TT.nets tech pages calls for like 36'' of over all length and swivel ends.
Old Oct 25, 2008 | 02:17 AM
F5 Hero
We got it, used i dunno 24" - 36" of extension, a swivel on the end, with someone on top looking in and guiding it. ON that note, there are 10 bolts in the bell housing, we only took 9 out.... and yes, we did drop the tranny... so.... weird.... (this is my parts car i recently purchased btw, not mine =-P )
For your enjoyment...
Old Oct 25, 2008 | 02:56 PM
KasbeKZ's Avatar
Pr0n Addict
you have a parts car? N/A? i need a ps pump...
$$$$$$$$ for you!
Old Oct 31, 2008 | 04:23 PM
F5 Hero
I have a TT parts car for my swap. I'll be keeping my NA ps pump obviously bc i will still need it ( can't use the TT pump bc of hicas stuff)
sorry =-( frownie face for you!
Old Oct 31, 2008 | 07:18 PM
KasbeKZ's Avatar
Pr0n Addict
thanks. i've just decided to rebuild mine with some brand new OEM internals anyway.
Old Nov 1, 2008 | 05:42 AM
rtmorgan's Avatar
Obsessive Craigslist Disorder
oh decided to rebuild it now anyways mine is fixed it was the little spring and control valve i didnt even need to take it all the apart the spring was worn and the valve has some **** on it so new spring and and cleaned the valve with my parts washer and good as new
Old Nov 1, 2008 | 09:33 AM
KasbeKZ's Avatar
Pr0n Addict
http://www.courtesyparts.com/300zx-z...3_991_996.html
parts 49160M and 49162M?
Old Nov 1, 2008 | 10:25 AM
rtmorgan's Avatar
i cleaned 49160m and replaced 49162m
Old Nov 1, 2008 | 11:18 AM
KasbeKZ's Avatar
Pr0n Addict
alright cool. thanks.
Old Nov 8, 2008 | 09:21 PM
Ih8rice's Avatar
Guess I'll throw in my 2 cents in case anyone else has this problem.
Lots of extensions with a swivel are needed but the key to it is to put a jack under the transmission, remove the bolts in the tranny crossmember and lower the tranny. When the back of the tranny drops it opens the gap in the transmission tunnel and angles the back of the motor allowing a straight shot to the bolts. Make sure to leave a few other bolts in the bellhousing so it doesn't drop when the top bolts are removed.
Old Nov 18, 2008 | 12:24 PM
F5 Hero
One thing i noticed, you can see the top bolts from the top. This makes it REALLY easy to get the socket on it. Also, if you have socketing wrenchs (i'm to poor for those) you can get it from the top with ease. I only took out 9 bolts of my bell housing... so no clue where the 10th was supposed to be..
Old Nov 18, 2008 | 01:22 PM
KasbeKZ's Avatar
Pr0n Addict
my bell housing was a little strange with bolts too. someone had not put it back together properly, and i didn't get it any better. maybe someday. when i change the clutch or something i'll take the time to get it right
i wasn't ever able to see the bolt from the top, just feel it. like i said, dad was pushing the socket up from below and i was guiding it on with my hand.
nissangeek
Jul 6, 2010 05:11 PM
81 Black L28E
Apr 21, 2005 08:19 AM
anlasak
Jan 25, 2005 01:26 AM
John
Jan 16, 2004 08:36 AM
ved00fel
Dec 12, 2002 05:52 AM
