steering problem
Old Jul 3, 2004 | 09:24 PM
Riz Z Speed's Avatar
Administrative Brown Guy
worn steering rack bushings.
check link page for retailers.
Old Jul 5, 2004 | 06:22 PM
z my duzt's Avatar
i also seem to have this problem with my 90 n/a 2+2 ! so i should replace the steering rack bushings? and what kind of power steering fluid should i use? how do you flush/drain power steering fluid?
Old Jul 6, 2004 | 05:42 AM
tnkrstoyco's Avatar
Loves Going Topless
Rizz, correct me if I'm wrong, but I've been using Dextron III ATF. I think the manual calls for Dextron ATF and I think the III is compatable with any type of ATF, but your NOT supposed to use power steering fluid in the steering or the HICAS.
Old Jul 6, 2004 | 12:15 PM
dextron III is fine.
to flush the system you should remove the return hose to the resevoir while running the engine to idle. The return hose should be feeding some container to dispose of the old fluid. when empty, reconnect the return line. fill to appropriate level with new ATF fluid.1 1/8 QT NA, 1 3/4 QT for TT with HICAS=1.3 Liter NA, 2.0 Liter TT.
http://www.300zx.co.uk/cgi-bin/manual.cgi
online manual
steering system section
page 14
diagrahm of steering rack, bushings shown
jeffers300
Mar 26, 2012 03:35 AM
RaZx
Nov 16, 2005 04:01 PM
oakdalenewbies
21
Feb 11, 2004 03:26 PM
djskiiz
Apr 16, 2003 01:04 AM
BlitZaceZ32
Mar 17, 2003 10:11 PM
