Steering Problem
Old Nov 16, 2005 | 01:02 AM
RaZx's Avatar
Steering Problem
I recently got a '91 n/a. It seems to run pretty well for the most part, but the steering is shot. There is enough fluid, but I have NO power steering.
It seems harder to turn left than to turn right. Whe I turn right there is a loud whining noise.
The car pulls to the right a little and you can feel a shimmy between 45 and 55 mph (most significant at about 50), although I'm sure an alignment will fix that problem.
What is the first thing I should suspect as the problem with the steering? PS Pump? Bushings? The whole setup?
The person I got the car from seems to think it's the rack and pinion system and that it will take quite a bit to repair, but I don't know if a mechanic told him that or if he is assuming.
Thanks
Old Nov 16, 2005 | 08:43 AM
emo236's Avatar
confuzed member
Could be anything. First, check to see if you PS lines are clogged at all.
Old Nov 16, 2005 | 01:02 PM
Riz Z Speed's Avatar
Administrative Brown Guy
dumb question, is the power steering belt intact?
sometimes it's the simplest things.
Also about the steering rack, you could try just lubricating it. In the FSM there's a diagrahm that shows various lubrication points on the steering rack.
Old Nov 16, 2005 | 04:01 PM
entropy31's Avatar
The Cake Is A Lie!
i would assume the belt is still intact if he hears the whine, which would mean the pump is turning. maybe the belt is loose and not turning the pump as much as needed. also, check for a clog in the system.
jeffers300
Mar 26, 2012 03:35 AM
roger749
Jul 6, 2004 12:15 PM
oakdalenewbies
21
Feb 11, 2004 03:26 PM
djskiiz
Apr 16, 2003 01:04 AM
BlitZaceZ32
Mar 17, 2003 10:11 PM
