starter issues
Old May 12, 2009 | 02:24 PM
KasbeKZ's Avatar
Pr0n Addict
starter issues
ever since i got this car, it occasionally takes me a few turns of the key to get the starter to go. then the starter works great. well finally it got to a point where i couldn't start it a couple days ago (turned the key about 20 times with nothing. accessories all came on just fine). i finally got a chance to check it out and i checked the ignition fuses and gave it another go, and after 3 or 4 turns, it started right up. i moved it onto ramps so i could check the starter out, cut it off, tried again, and it worked again. so now i have a problem. i have nothing to test, because it works. it won't work forever, and may leave me stranded next time i take it out. whenever i turn the key and the starter doesn't turn, i never get a click. i'm thinking the solenoid?
Old May 12, 2009 | 05:24 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Replace the starter relay.
Old May 12, 2009 | 06:51 PM
KasbeKZ's Avatar
Pr0n Addict
i pulled that out and it looked brand new. inside the connections was just flawless. but yeah, i think i'll try that. next time it happens, i'll be able to test stuff. i hope...
Old May 12, 2009 | 08:13 PM
That relay has been troublesome for people in the past, regardless of age.
Old May 12, 2009 | 08:22 PM
KasbeKZ's Avatar
Pr0n Addict
hmm. good to know. thanks. that's one expensive little tiny item though lol.
have you ever heard of rigging up a different relay from another car to work? so it would be more reliable?
Old Sep 17, 2009 | 02:36 PM
KasbeKZ's Avatar
Pr0n Addict
just to close up this topic for record's sake:
i replaced the relay, problem completely fixed. and i didn't spend $70 on a new one from courtesy. i got one from advanced auto for $17. and it's great. so i'll see how long it holds up. probably longer than i'll have the car so it's all good!
Old Sep 17, 2009 | 02:54 PM
Of course the problem was fixed... I told you what to replace.
Old Sep 17, 2009 | 03:36 PM
KasbeKZ's Avatar
Pr0n Addict
yeah i know! i didn't doubt that was the problem! and thanks for that advise. i really wouldn't have figured that one out if it didn't come up while searching.
El_Colombiano
Jan 18, 2013 03:36 PM
Flacster
Jul 11, 2011 12:05 AM
vvillium3
Aug 21, 2005 09:06 AM
81 Black L28E
Jun 1, 2005 11:58 PM
AlongCamePeter
Sep 12, 2004 06:20 PM
