someone help me please!!!
Old Jan 31, 2005 | 08:10 PM
91zxtt's Avatar
Check for a clogged air filter, bad O2 sensor(s), and wrong/fouled plugs.
Old Jan 31, 2005 | 08:12 PM
Mgharaati's Avatar
hmmm... im not sure .... did they do anythign to your injectors at all...?? i changed my injectors on my 91 NA a while ago and 2 days after i noticed the car was running very rich and didnt want "to go".... long storry short i ended up taking off the entire manifold again and removing the injectors and installing them again with new O-rings.
what had happened in my case was that my o-rings that i installed the first time around had curled up durring installation and once the engine got hot and cold and hot and cold a couple of times that o-rings integrity was jeopardized by the fact that it had curled up and so it started leaking fuel into the combustion chamber.... changed the orings... problem solved !
if thats not the case... maybe an o2 sensor ... or the ECU.. i dont know.. just thought i would share a story... when you find out what it is ... let us all know
