Rough idle and suspension help for rookie
Old Apr 12, 2004 | 02:35 PM
91zxtt's Avatar
If the shocks are original, then after 115k + miles, they're most likely shot. The springs are probably worn also, which could cause sagging. You could go with the factory set up; i.e. new OEM shocks and springs. This is generally more expensive than if you went with an aftermarket setup. I had 150k on mine before I changed out the shocks and springs. Eventhough I switched to Tokico Illumina shocks and Eibach pro springs, the ride was much smoother than the previous setup. If you want to keep everything stock, then I would recommend you replace at least the shocks. You could possibly get away with not replacing the springs.
A tune up could fix your problem. It will at least reduce the rough idle problem. Change the plugs and the fuel filter, then clean the air filter also. since there's no cap, rotor or plug wires, a tune up is pretty simple.
Old Apr 12, 2004 | 03:44 PM
Riz Z Speed's Avatar
Administrative Brown Guy
I think oem suspensions usually last around 50-60K. About the time that the drivetrain warranty runs out.
Old Apr 12, 2004 | 06:12 PM
91zxtt's Avatar
Some people say that the OEM suspension components begin to wear out after as early as 30k.
The Z32 is not known for having a harsh ride feel to it. You'll really notice an improvement in the ride quality by installing new shocks; whether they're factory or aftermarket.
MR2ZX
Feb 11, 2013 09:25 AM
ryencoke
FS: 300ZX (90-96)
May 18, 2012 11:45 AM
Sp4rt4n
Oct 13, 2006 12:55 PM
John300
Dec 2, 2002 09:09 AM
jbaran1123
Nov 8, 2002 07:01 PM
