Quick advice
Old Jan 21, 2004 | 02:08 PM
emo236's Avatar
confuzed member
Definitely an ecu. And can I recommend the AshSpec instead of jwt? It's 300$ cheaper and has safer, more effective programming. A boost controller is somewhat useless without an ecu because you need you fuel and air mixtures (and a bunch of other stuff) to change to be able to safely boost over stock boost limits. Heck, if you get the AshSpec, you may even be able to afford both!
Old Jan 21, 2004 | 02:58 PM
Z_WRECKER's Avatar
i have to agree...get an ecu and a boost controler, that is if you go with AshSpec... just shop around...i dunno your feelings about ebay but you can find a boost controler pretty cheap. but if you shop around i am sure for the price of JWT you can buy both.....that is if you send your ecu in so you don't have to pay the core charge
Old Jan 21, 2004 | 03:59 PM
emo236's Avatar
confuzed member
Good choices...the profec b is an excellent boost controller.
Old Jan 21, 2004 | 05:53 PM
Z_WRECKER's Avatar
yeah thats what i was saying get an ecu from z1 then check ebay for a boost controller......i would never buy an ecu from ebay...God knows whats in it
Old Jan 21, 2004 | 10:05 PM
91zxtt's Avatar
Absolutely do not buy an ECU from eBAY. Before you buy the ECU, you should buy a high flow intake and a cat-back exhaust system. The ECU is your 2rd step. Make sure you take the 1st 2 steps. The ECU upgrade is designed to work better with the modified intake and exhaust.
Cheers!!
Old Jan 21, 2004 | 10:28 PM
emo236's Avatar
confuzed member
Yea, I was thinking the same thing. Usually, it works to get the intake, then exhaust(or vice versa) then the ecu. The ecu is programed to work with the freer flowing system. You'll be at stage three and you'll be very pleased. you could pick up an intake for less than $200, then start saving up for an exhaust.
Old Jan 21, 2004 | 10:37 PM
emo236's Avatar
confuzed member
I did a little ebay shopping for u.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33630
I have this exhaust and I'm happy with it. Also, look into HKS Hipers...great value. Cheap and the best flow I believe.
Old Jan 21, 2004 | 10:50 PM
emo236's Avatar
confuzed member
Sounds like an outstanding deal!!! But get a compression test done as well and take it for a long long test drive and look at it forever..up and down..sideways. That's such a low price that it's awfully suspicious. He might have been stage two for while and he may have raised the boost via welding tips and taken them out so you would never know and done some valve damage or detonated a bunch. go in with a suspicoius mind, but if it all checks out good after eyeing it over hardcore...don't let a deal like that pass up!
Old Jan 21, 2004 | 10:53 PM
91zxtt's Avatar
The 1990 model year had some gremlins. It was the 1st year for the new car, so it was expected. I would be concerned with that, but if you've driven it, and it feels good, and you feel good about it, then do what you want to do. $5kish sounds like a good price, assuming good overall condition, inside and out. The ECU would take you to stage 3; which is a shade over 400 HP. If you could find something '91 or newer, I would recommend that, but it's your call.
Old Jan 21, 2004 | 10:57 PM
emo236's Avatar
confuzed member
Check the VIN. If its under a certain number...be VERY wary. I'm not sure which one..do some research on that (I dont feel like doing it right now...lemme know if you really can't find it).
Old Jan 21, 2004 | 11:00 PM
91zxtt's Avatar
Oh come on Emo, help the kid out. You'll still be up for another 3 hours. Some of us have to work in the morning to pay for our habits. I'm outta here until tomorrow.
Old Jan 21, 2004 | 11:21 PM
emo236's Avatar
confuzed member
Ok, I found it:
The 'soft' valve problem *could* be in NA engines with serial numbers lower than 777599, while TT engines are lower than 619550. The engine serial number is located on the rear of the passenger's side head. Car assembly dates are earlier than June 22, 1990 for NA's and December 11, 1989 for TT's. The intake cam problems are NA ENGINES ONLY, and are for engine serial numbers lower than 475679 in cars with VIN's lower than 012836 for the coupes and 003754 for 2+2's
Old Jan 21, 2004 | 11:55 PM
emo236's Avatar
confuzed member
They're all about the same which is good. They say that they should be no lower than 130 and no higher than 170..so in other words...great test results...looking like a good car so far...hows the VIN match up to the info I gave you?
Old Jan 22, 2004 | 12:01 AM
Riz Z Speed's Avatar
Administrative Brown Guy
Is the timer a timer only? Or is it possibly a boost controller as well? Only asking cuz nowadays they're incorporated into one unit.
Old Jan 22, 2004 | 12:06 AM
emo236's Avatar
confuzed member
Where'd you get that, Rizz? I think most boost controllers have an incorporated turbo timer, but most turbo timers don't double as a boost controller. IF that was true...heck...boost controllers could be had for less than $200.
Old Jan 22, 2004 | 12:08 AM
emo236's Avatar
confuzed member
Yea...thats what I have...definietly just a turbo timer...I'm almost 98% sure.
Old Jan 22, 2004 | 12:11 AM
just checking all the bases.
Old Jan 22, 2004 | 12:24 AM
emo236's Avatar
confuzed member
Hey, Lynx...have you checked the VIN numbers?
Old Jan 22, 2004 | 10:43 AM
emo236's Avatar
confuzed member
NO look up a few posts and some of the 90s cars (89 actually) had a problem called soft valves and it applies to certain VIN numbers...compare the VIN to those numbers.
Duck Ryder
Aug 23, 2007 04:51 PM
Skully
Aug 31, 2005 09:09 PM
DoTheDrew888
Aug 3, 2005 03:26 PM
zkyle
Sep 7, 2002 10:14 PM
zkyle
Aug 25, 2002 09:10 PM
