Question about turbo stuff I read??
Old Sep 29, 2004 | 01:59 PM
CaptainZ's Avatar
I was reading on Z1 motorsports about being able to just add turbo components to a non-turbo engine. It says it can be done, but if you maintain n/a pistons, you can only run low boost. What amount of boost can the n/a engine with stock pistons handle?
Old Sep 29, 2004 | 02:30 PM
ZXDude90's Avatar
Aqua Teen Hunger Force Fan
Hmm... That's new to me. I've never heard of adding turbo components to an n/a. *shrugs*
Old Sep 29, 2004 | 02:59 PM
CaptainZ's Avatar
http://www.z1motorsports.com/PDFs/NAwTTs(partsprices).pdf , or just go to www.z1motorsports.com, click on techinical info on the left hand side, and under engine tech click the "n/a engine with turbo components installed" link.
Old Sep 29, 2004 | 03:00 PM
91zxtt's Avatar
I'm sure it can be done, but why? You'd need the turbos, TT exhaust manifolds, mid pipes and the intercooler with all the piping. You'd also need to add intercooler vents in the front fascia. The reason you'd have to run less boost is because if the increased compression ratio in the N/A. You also have an issue with insufficient fuel supply. I would estimate 6-8 psi or so. Not worth it IMO.
Old Sep 29, 2004 | 04:30 PM
CanyonCarver's Avatar
Jack Of All Trades
I'm not going to do the math here, but 6-8 psi in a 9.5:1 c/r engine would make a bit more h.p. than a stock TT. You can turbocharge any engine and increase boost until you start to run lean. That's why you need an air/fuel ratio gage.
Old Sep 29, 2004 | 05:05 PM
91zxtt's Avatar
Don't take my word for it. I'm just guessing. I've never seen it done, so I don't know. You may only be able to run 4 psi of boost with the stock N/A internals without it going *POP*. The stock TT runs 9.5 psi, so it'd be significatnly less than that.
Canyon....what equation did you use to come up with that?
Old Sep 29, 2004 | 07:36 PM
Jack Of All Trades
Like I said I didn't do the math ...... yet. I have to some searching.
So I found a calculator that shows how boost increases your compression ratio, ie: 8 psi and 8:1 goes to 11:1 c/r AND 8 psi and 10:1 goes to 15:1 c/r. Now I'm looking for a calculator that show how the increased c/r increases h/p
Old Sep 29, 2004 | 09:33 PM
My Fairlady Z's Avatar
Ruined By Spudz
yah my ricey *** friend did that too his honda..put a no-name blow off on it lol..i think he lost H.P over it in the long run because it cant hold pressure for **** lol its like "riiiiiiiiiiice'splish* lol the blow off makes a lower sound then an old man easing into a warm bath..
Old Sep 30, 2004 | 10:21 AM
91zxtt's Avatar
Oops. Momentary lapse in literacy.
Old Oct 1, 2004 | 06:14 AM
Jack Of All Trades
I was playing with these calculators:
http://www.bgsoflex.com/crchange.html
http://www.rbracing-rsr.com/comprAdvHD.htm
300zx TT stock c/r 8.5:1
5.5 psi 9.5:1
8 psi 10.67:1
10 psi 11.61:1
12 psi 12.55:1
300zx n/a stock c/r 10.5:1
5.5 psi 11.69:1
6 psi 11.98:1
12 psi 15.46:1
In comparision, you only need to run 5.5 psi on the n/a to achieve (roughly) the same performance of a TT at 10 psi.
FLAME ME !!!!!!!!!!!!!!!!1
Old Oct 1, 2004 | 10:18 AM
91zxtt's Avatar
Not from me. I only flame when I have at least 1/2 leg to stand on in an argument. I don't have that 1/2 leg on this one.
NismoPick
Feb 22, 2009 11:59 AM
NismoPick
Feb 22, 2009 11:58 AM
Nemesis280zx
Sep 4, 2007 12:20 PM
hellraZor
May 26, 2005 04:55 PM
crazywing99
Apr 26, 2004 07:00 PM
