oil pressure
Old Sep 19, 2007 | 06:26 PM
KasbeKZ's Avatar
Pr0n Addict
oil pressure
my Z32 with 150k has good oil pressure until it idles after heating up. at this point it bounces around between 0 and 10. bearings? pump? can i drop the pan and change the pump? thanks for all the help lately. it has been a rouph switch from my british cars now to japanese. and i have changed the oil: 10W-30 castrol high mileage with a K&N filter
Old Sep 19, 2007 | 08:07 PM
91zxtt's Avatar
10w30 is pretty light for a z with 150k on it. You could try a hgher weigth oil.
The reason you're oil pressure is reading low is liekly due to the oil pressure sending unit going bad instead of any of the problems you mention.
Since you're used to British cars, I can't fault you for thinking that the problem is more major. Nissan Z engines are pretty bullet proof. British cars are um.....not.
Old Sep 19, 2007 | 11:49 PM
Z Car Barbie's Avatar
User Friendly
Originally Posted by 91zxtt
The reason you're oil pressure is reading low is liekly due to the oil pressure sending unit going bad.
Yeah, it's a common problem with all Z's. I've replaced several on my Z's, and only use 20/50 weight oil, which doesn't help the sender reading. They're usually just not that accurate, even when they do work properly. Best bet is to check your oil weekly and change it regularly, when it's due.
Old Sep 20, 2007 | 04:14 PM
KasbeKZ's Avatar
Pr0n Addict
thanks
well thats good news. lol thanks for understanding the british car scenario.
Old Sep 21, 2007 | 08:21 PM
91zxtt's Avatar
I had a '76 MG Miget, so I completely understand; in fact, moreso than I truly ever wanted to.
FubarI33t
Apr 27, 2010 08:45 PM
FubarI33t
Dec 12, 2009 10:03 AM
tonsoffun300zx
Sep 21, 2009 10:51 AM
y2daniel1981
Oct 25, 2006 10:24 AM
91zxtt
Mar 5, 2004 11:00 AM
