Noisy fuel pump?
Noisy fuel pump?
Hi everyone! First off, I apologize if this question has already been answered somewhere; I did a search and didn't find what I was looking for. Here's the deal: I have a '90 N/A 5-spd. that seems to have a noisy fuel pump. When I first start the car, until it's warmed up, and when I'm on the throttle more than, say, 10-15% while driving, I hear a high pitched buzzing/whine sound. It's defnitely coming from the hatch area and seems to be the fuel pump. Is this normal? I don't know much about the history of the car as I bought it at 183k with a bad engine and had a 30k mile replacement installed. I would assume the fuel pump has never been replaced but again, not knowing the history I can't say for sure. Any input is appreciated. It doesn't seem to be causing any problems but it is a bit annoying. Thanks guys!
Originally Posted by CanyonCarver
My fuel pump is noisy in the same way. It's been that way since I bought my car two years ago. I don't consider it a problem.
It's likely a sign that the pump is on its way out... how much longer it'll live is uncertain, but try to keep your fuel tank from getting too empty (the pump is fuel cooled, so as long as you keep a decent amount of gas in the car, it should last a bit longer). Be prepared to replace it, but other than the cost of the part, it's a pretty easy job.
Queen of Yachts
some fuel pumps are supposed to make a clicking or whirring sound--prior to ignition, to bring fuel to the injectors. ion some race cars, this initial pump shuts off after the engine is warm and the pump is no longer needed. i am able to hear the fuel pumps on myz31's--not loudly, just distinctly, because i know the sound--do yours keep making more and more noise? or is it consistent and constant?
Originally Posted by z-hag
... on some race cars, this initial pump shuts off after the engine is warm and the pump is no longer needed.
Your pump has two speeds (TTs have 3), it doesn't vary with engine speed. My guess is that your pump is having trouble at its higher speed (the lower speed is for super-low RPMs and idling). Like I said, don't be surprised when it does fail, but there's no telling when that'll be.
Coz... www.czp.us (call and ask for Coz)
RonK
Feb 11, 2013 08:48 PM
sameerb1
Mar 20, 2011 05:21 AM
mrprofile
Jun 25, 2010 11:23 PM
ern
Oct 20, 2006 07:01 AM
