no ignition
Guest
Posts: n/a
no ignition
My baby is a '91 manual NA. Today morning it reffused to start. When I crank it, I heard like a normal starting noise for a sec, but then it was just a cranking without ignition. All the controll lights ok hut have no ignition? Anybody have a idea what happened? Ignition, fuel pump? Was something similar listed b4?
Thanks
Atis
Thanks
Atis
Guest
Posts: n/a
it doesnt hurt to check the battery. wipe off the connections, jiggle things around, and then try it. Mine wouldnt start, and either that or changing the starter relay fixed it. I did them both at the same time... oh well. twinturbo.net has a write up on the starter relay. it was under $50 bucks from nissan I think.
hope that helps man,
jon
let us know what happens
jon
Guest
Posts: n/a
An smart autoelectrician solved my problem, but You was really close to the solution!
A nasty contact error was guilty. There is a bunch of cables going into ignition unit and their connector got loosen a bit. It was just enough to shake the connector on right way and tadaa...
This guy also showed me where to shake (right under the ignitor unit - which is hidden behind of left trottle pipe) if happens again, but I think I'll let inspect the connector at the next service.
Jonnyz, thanks for reply and for your effort!
Cheers
Atis
Cheers
Atis
