no. 1 and 6 cylinders not firing?
Old May 8, 2012 | 08:11 PM
  #26
chilly willy's Avatar
HA HA HA im glad im a good problem solver i found the issue. !!!!!!!!!
Old Jul 14, 2012 | 05:02 PM
  #27
kloc07's Avatar
i'm having similar problems since my swap. what was it?
Old Aug 30, 2012 | 08:24 PM
  #28
smurffz32's Avatar
hey maing ***** all the b ** ppl talk
Originally Posted by devildogzx7r
ok so for those of you who still wanna help me and not fight with bartz32. i just went and checked all my injectors. and they all have 11.9 ohms. what kind of aerosol spray can i buy to clean connectors with. i looked at walmart and they didnt have ****. so im gonna try autozone tommorow. but right now i still have the problem narrowed down to either the ptu or engine harness.
So i was searching for some help due to the same issue i have with z and came across your tread.ok i just did a swap due to a blown motor and hear is what i have found out so far first i had no spark at all in all cylinders after i was done my swap i tried starting it and it crank but no start.well w t hell so i figured i change all my coil packs from my old motor cause i knew they were good.nothing happened so i went n got the ptu and cas from my old engine and put them on, guess what it fired and died.so i decided to look in to the connectors for the ptu they were bad so i went and bought electrical connection cleaner from radio shack cleaned them but didn't brush anything i just let the fluid sit for 10 min and air blow it.guess what it started after except i had no 5 and 4 not getting spark the car runs like a bag of s.... it shakes a lot and even sometimes die.so now i'm guessing the only thing is there has to be either 2 or more connectors that i haven't cleaned proper beside that she good well except some vacuum line i need to figure out.and for all the ppl saying oo it's your injector injector oo.forget that get a spark goin in that cylinder and go from there.beside if u have fuel groin the and injectors working but no spark i'm sure if you pull the spark plug out after ruining the car for 2 min you will see your spark plug wet.there i'm a 3rd year tec don't know a lot but i know enough. i will keep u posted what will happen after cleaning all that corrosion from the ptu connectors.
Old Jul 23, 2013 | 08:40 AM
  #29
chkootje's Avatar
maybe sounds a little crazy but bought a 300zx running on 3 cyl and got it to run on 5 cyl just by resetting the ecu. the last one had a broken injector. hope it helps you, i have no idea why it worked, but it worked for me.
good luck
r2doesinc
18
Mar 14, 2016 06:04 PM
k1drift
May 29, 2011 07:36 PM
Twin_Turbo_300z
Jul 20, 2010 01:38 PM
entropy31
Other Cars
Jul 31, 2005 01:21 AM
