ngk PFR6G-11 questions
Old May 22, 2006 | 09:16 PM
DSR300zx's Avatar
im going to be replacing my plugs sometime this week...i just wanna make sure these are the oem plugs for the N/A 300zx's, and if u guiys would recommend it, or get something better...i dont have much done to the car right now, just intake and soon hks exhuast...im a believer in stock plugs, unless i have something majorly done to the car...let me know guys, i did the best i could with a search before i asked
Old May 22, 2006 | 10:51 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
There are no better plugs for the Nissan 300ZX
Old May 23, 2006 | 08:19 PM
DSR300zx's Avatar
even for a N/A application?
Old May 23, 2006 | 10:24 PM
Riz Z Speed's Avatar
Administrative Brown Guy
stock car, stock plugs, 2nd.
Old May 24, 2006 | 02:23 AM
92fairladyz's Avatar
This is taken from Ash Powers' write-up in the 6 P's (Proper Preparation Prevents **** Poor Performance):
To mitigate the posibility of 'spark knock', you should use a spark plug that has a higher ability to dissipate heat. This simply means you need a plug with a higher 'thermal dissipation' number. Here's the breakdown:
NA stock: PFR6B-11 ; upgrade to the PFR7B-11
TT stock: PFR5B-11B ; upgrade to the PFR6B-11B
To view the rest of the 6 P's, go to:
http://twinturbo.net/net/viewmsg.asp...&msg_id=922678
Old May 24, 2006 | 04:09 AM
CanyonCarver's Avatar
Jack Of All Trades
3rd...........
Old May 24, 2006 | 08:48 AM
DSR300zx's Avatar
ok, so lets get this straight, which are the best NGK plugs to go for on a 93 N/A z? and why? like standard or colder plugs?
Old May 24, 2006 | 09:19 AM
Jack Of All Trades
I won't argue for or against the colder plugs. I have to see some facts on the benefits. I will argue for the stock plugs based on the fact that the motor was designed by Nissan for use with the PFR6B-11's.
Old May 24, 2006 | 09:31 AM
DSR300zx's Avatar
sounds good then, ill be getting the NGK PFR6B-11
Old May 24, 2006 | 03:22 PM
DSR300zx's Avatar
k i just ordered my plugs, will get them Friday....just wondering what is the correct gap?
Old May 24, 2006 | 03:37 PM
91Zman's Avatar
Opinionated
Hey i saw the thing about the upgraded NA plugs? opinions on that? what ups do you need to run those?
Old May 24, 2006 | 05:18 PM
If you are running a stock Z then a stock plug will work just fine. If you plan on modifying your Z then I say go with the colder plug. I went with a colder plug on my TT and had a noticeable difference. Then again, I was a Stage III TT running on NA plugs. In Japan the TT came with NA plugs stock. Just goes to show how stock doesn't always mean best.
Old May 24, 2006 | 06:18 PM
DSR300zx's Avatar
k, well i got the NGK PFR6B-11, can someone tell me the gap for the plugs?
Old May 24, 2006 | 06:53 PM
91Zman's Avatar
Opinionated
My car isnt stock. Im running stillen ported headers, intake, exhaust, ud pullies, will be getting ECU from Ash soon as well. Would this put me in the upgraded plug category?
Old May 24, 2006 | 06:54 PM
91Zman's Avatar
Opinionated
Search for it, i know that info is around somewhere
Google for something like (Your cars year) 300zx spark plug gap
Old May 24, 2006 | 09:36 PM
b300z's Avatar
caught the z fever
you shouldnt have to change the width
n/as usually dont really need a colder plug, but imo youre probably getting close to needing some
Old May 24, 2006 | 10:02 PM
the plugs come pre-gapped
Old May 24, 2006 | 10:09 PM
I don't know too much about upgrades on an NA. I do know it couldn't hurt to get the colder plug.
Old May 25, 2006 | 04:13 AM
Jack Of All Trades
I looked around and couldn't find anywhere that the plug gap was specified. I don't remember what it was, cuz I always ask the guy when I buy them and I'll write it on one of the boxes. Anyways, when I did my plugs on the Z, I had to adjust two of them so they aren't always correctly pre-gapped. I did have to open the gap up.
If all else fails, just make sure that all six plugs are the same gap, whatever they are.
Old May 25, 2006 | 08:33 AM
b300z's Avatar
caught the z fever
hmm, i never had a problem with the gaps, they were always the same
i need to get some colder plugs tho, i just detonated a bit yesterday
Old May 26, 2006 | 07:54 PM
91Zman's Avatar
Opinionated
I cant find any PFR7B-11 plugs anywhere, can someone link me?
Old May 26, 2006 | 08:06 PM
AcesFullof10s's Avatar
I believe for an NA it's .044"
Old May 26, 2006 | 09:50 PM
DSR300zx's Avatar
yes it is, i found it out, thanks again guys
Old May 26, 2006 | 11:00 PM
UltimateZ.com > Z32 300ZX > Performance Parts > Engine & Related Parts > Ignition > 2nd item from the bottom
When you can't find something, it's always because you're not searching hard enough.
Bdan57
Feb 5, 2010 12:42 PM
81-280zxnt
Nov 23, 2009 01:24 PM
81-280zxnt
Oct 20, 2009 12:02 PM
skittle
Jun 16, 2006 08:05 AM
pearly whites
Aug 18, 2004 06:20 PM
